will too much fluid cause this?
Old Mar 1, 2011 | 06:56 PM
LS1TRUCKGUY's Avatar
Default will too much fluid cause this?
Long story short, I had my 60e rebuilt by a local guy. I put it in today, put 5qts in to start with, start up the truck, and put in 4 more quarts and check the level. Its showing to be overfilled. The converter already had fluid in it. I back out of the driveway. 1-2 shifts is fine, goes to shift into 3rd and nothing..... I checked the fluid again and its still a little high.
Old Mar 1, 2011 | 06:58 PM
Bluchevypick's Avatar
No, Unless the overflow is stopped up. I always run my transmission a little over full.
Old Mar 1, 2011 | 07:07 PM
Great. That's not what I wanted to hear
Old Mar 1, 2011 | 07:44 PM
Hopefully its just something in the valve body so I don't have to pull it again. Lol
Old Mar 1, 2011 | 08:20 PM
How is that 80e treatin you btw?
Old Mar 1, 2011 | 08:23 PM
Goose33's Avatar
I have always heard if u run it to high it can ruin ur clutches but I guess maybe not! Hopefully u get it figured out
Old Mar 1, 2011 | 08:25 PM
terravast4's Avatar
frank with performabuilt says running too much fluid can cause as much harm as running not enough....just sayin.
Old Mar 1, 2011 | 09:28 PM
fredkj3's Avatar
running it a little high i dont see much happening but if its to high i could see it foaming and causing eratic pressure... flt or performabuilt did a right up on it once... they kept adding it or something till they seen a change...
but i dont think that this is your problem
Old Mar 1, 2011 | 11:25 PM
I just spoke with the builder. He told me to drive it and see if it has od. If it doesn't, its most likely a check ball. If it does have od, he said it may be the sprag. I hope its just a check ball...
Blwn99x
Mar 24, 2023 11:14 AM
drummer0415
11
Oct 24, 2015 08:16 PM
turbo6c3
Oct 5, 2015 06:11 PM
fortune46x
Sep 16, 2015 08:18 AM
Noah Burns
Sep 13, 2015 09:28 AM
