will new shocks make 4/6 ride better?
Old Jan 22, 2005 | 07:25 PM
hyper's Avatar
Default will new shocks make 4/6 ride better?
will getting new shocks make the ride smoother?
Old Jan 22, 2005 | 10:28 PM
Nick99Chevy's Avatar
What shocks do you have now?
Old Jan 22, 2005 | 11:14 PM
O3GMC's Avatar
12 Second Club
On my 2-4, Ive tried doetsch tech, edelbrock IAS and stock, and stock rides best by far. For handling, the IAS is definetely the way to go. But the roads around here suck too bad to be flying around corners anyways. However I recently swapped out my suspension and I'm using the stock springs now, so maybe the IAS would work better now. I'm going to try them out again sometime soon.
Old Jan 22, 2005 | 11:17 PM
desTRUCKtive's Avatar
if you are using the stock shocks on the drop. then getting some shorter shocks will for sure help you out.
Old Jan 24, 2005 | 07:50 AM
Scream's Avatar
MOOBIES Moderator
Not on the 4/6 if it's a DJM drop. The DJM drop is all control arm, meaning you keep the factory coil springs and shocks up front.
I've always like Bell Tech Nitro Drops. All I've used for 10 years.
Old Jan 24, 2005 | 08:01 AM
True, at the time I was thinking also about the rear shocks, you do need new shocks for the back. I have DJM and they told me that I needed shorter ones in the front, Right know I have shorter ones in the front. But it does make sense since you are not changing the length of the coil spring.
Old Jan 24, 2005 | 08:53 AM
I am running Stock length Monroe Sensa-Tracs in the front and drop shocks w/helper baggs in the rear. The Monroes ride alot better than my Toxic and Belltech(lasted maybe 2,000 miles) shocks.
Old Jan 25, 2005 | 01:27 AM
chris99gmc's Avatar
are you sure that you retain the stock length shocks with those 4" lca's?
I knew that they raised the spring pocket, but doest the shock compress more or am i wrong here?
Old Jan 25, 2005 | 06:55 AM
Scream's Avatar
MOOBIES Moderator
Yup. You retain the factory coil spring and shocks for the front...the rear needs shorter shocks b/c of the flip kit.
Old Jan 25, 2005 | 12:16 PM
OUT2WIN's Avatar
I like the belltech nitro drop shocks as well. I am running air shocks in the back so I can lift it a little every now and then.
