What are y'all guys doing to upgrade the tranny?
Old Jul 31, 2010 | 06:32 PM
mhotrodscooter's Avatar
Default What are y'all guys doing to upgrade the tranny?
I know theirs the shift kit! But want else? R these mods fairly easy to do for a shade tree guy? And does the tranny have to be pull?
Old Jul 31, 2010 | 07:09 PM
TX Tahoe Z71's Avatar
Vette servo, tru cool 40,000 gvwr cooler, both found on eBay. Trans doesn't need to be removed for hd2 shift kit, servo or trans cooler.
Do a search on here, there are a few threads with good parts lists. I would post up a link, but I am posting from my PDA and it would take 20 min to dig the thread up from it.
Old Aug 1, 2010 | 10:24 AM
fredkj3's Avatar
i had good luck with a cooler and shift kit.. its held out way longer than it shouldve behind the 6.0.. but its like the lottery... you could blow it tomorrow at 1/4 throttle....
Old Aug 1, 2010 | 04:34 PM
.James.'s Avatar
ill be installing my transaver cooler soon from hayden with the help of iamkeniff, i was thinking of addign the hd2 shift kit, but i really dont want to mess with the trans at all. I have a 2600 tb converter, servo. thats about going to trans. so i got a deal on my hayden cooler, i am scared to mess with the trans honestly
Old Aug 1, 2010 | 05:46 PM
rmck490's Avatar
I have the shift kit, stock TC, vette servo, and the 4th ply servo. I also replaced the three accumulators with pinless accumulators, all of the solenoids (1-2, 2-3, 3-4, PCS, PWM, TCC, and the in pan wiring harness), and replaced the seperator plate and check *****. I went with the highest capacity Hayden trans cooler I could get as well.
I had a P0748 code and my diagnostics for the problem led me to the pressure control solenoid (PCS). I also had a P1870 code (once). My TC wasn't locking up correctly either at about the time I got the P1870 code. Figuring I was going to be inside the pan, I chose to do as much as I could while I was in there (including replacing the filter). Truck had 109k on it so I was just trying to do some preventative maintenance.
Truck shifts great now in all gears (you can definitely feel the difference) and the TC locks up when it's supposed to. The vette servo firms up the 1-2 shift tremendously. It's well worth the money (~$18 including shipping) and easy to install. With the trans cooler my temps run about 10 to 20 degrees lower than before. The shift kit takes time, you need to read the instructions thorougly, and don't get in a hurry. If it takes to two days to get it right, take it.
All this was done without taking the trans out. Putting in a higher stall TC would be a different story.
Old Aug 1, 2010 | 07:54 PM
SnakeOiler's Avatar
I upgraded my tranny by calling FLT.
Old Aug 2, 2010 | 02:08 AM
Thanks guys!
Think I'll get everything & do a converter 2!
As soon as I can can get a good dyno pull!
Old Aug 2, 2010 | 02:11 AM
Really like to do it myself!
But if I blow it, then I'll half to call someone lol
Old Aug 2, 2010 | 03:29 AM
2007chevy5.3l's Avatar
Ive got the vette servo, 40k cooler, upped line pressure via efilive and have changed the trans fluid twice with only 45k miles on it. Shifts great and is still holding up.
Old Aug 2, 2010 | 09:47 AM
SILVERADO11's Avatar
Im going with a new trans from FLT.
