Turbo guys i need some help with gear ratios...
Old Sep 22, 2006 | 07:58 PM
nonnieselman's Avatar
Default Turbo guys i need some help with gear ratios...
Ok i will have a STS kit with 6psi along with a built tranny and 3k stall.
Should i go with the 4.10s i have sittin on my back seat, or stick with the 3.42s that i already have?? I have a Eaton LSD that im goin to put in to replace the Grenade-80.
Oppinions please!!!!
Old Sep 22, 2006 | 08:01 PM
i would go with the 4.10's because you are going to need as much low end as you can get with the turbo!
Old Sep 22, 2006 | 08:11 PM
even with the 3000 stall?
Old Sep 22, 2006 | 08:43 PM
ColtSteele's Avatar
I've wanted to ask this same question. Im running 4.56's and a 3k stall and I'm worried that it's too much gear too. ttt
Old Sep 22, 2006 | 08:44 PM
OLD BULL's Avatar
I'm no expert, but I think you will be better off with the 3.42 gear vs the 4.10. Turbos supposedly love gear. Something to with loading the engine/turbo. You will not build boost without putting a load on the engine. Hopefully someone with more knowledge will come here and elaborate.
Old Sep 22, 2006 | 08:46 PM
Dock Rocker's Avatar
I have heard that they like higher ratios b/c it helps create a load that increases the exaust that turns the turbo faster. Deeper ratios put less load on the motor (why your around town milage goes up with the 4:11's) so there is less exaust gas to build boost.
Old Sep 22, 2006 | 08:59 PM
quicksilverado's Avatar
I have 3.42s a 4l80e and a 2800 stall. This is with street tires.
http://www.incontt.net/videos/Quicksilverado12-47.wmv
This is with slicks and a 2-step.
http://www.incontt.net/videos/QuicksilveradoMMP.wmv
And from a roll. 8 psi on a stock 5.3
http://www.incontt.net/videos/quicksilverado-roll.wmv
4.10s will not allow the turbo to build boost until you are well past 1st gear.
Old Sep 22, 2006 | 09:09 PM
So thats why you told me to keep the 3.42s...
Im goin to take your word on that.. i guess im goin to sell the 4.10s then..
that away i can keep my nice low rpm interstate speeds.
Old Sep 22, 2006 | 09:10 PM
anyone else got an opinion?
Old Sep 22, 2006 | 09:12 PM
cablebandit's Avatar
9 Second Club
3.42...4.10 will kill spool up and make your converter tighter.
Quicksilverado...looking at those vidz, I can tell your camera man is a trained professional!! We gotta make some more SOON!!
