Turbo guys i need some help with gear ratios...
Old Sep 22, 2006 | 09:13 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I agree with David for RCSBs. Extended cabs, however, have enough weight to run 4.10s. That's what I run, and have always run. I build boost easily in first, but admitedly have a lot more exhaust pressure than a stock truck .
Old Sep 22, 2006 | 09:16 PM
quicksilverado's Avatar
Your 408 pushes alot more air Erik.
Old Sep 22, 2006 | 09:17 PM
nonnieselman's Avatar
so some say keep the 3.42s,,, but the weight of the EC actually helps the 4.10s...
Man there are so many choices........
Old Sep 22, 2006 | 09:20 PM
ColtSteele's Avatar
Originally Posted by quicksilverado
4.10s will not allow the turbo to build boost until you are well past 1st gear.
Thats what I thought too so I figured my set up, 4.56's, wouldn't let me see high boost in low gears. Last week while doing some street tuning, 1st and 2nd gear, we rolled into it from a light and hit 20psi before the 1-2 shift. Surprised me. I may still look for some 3.55's or 4.10's
Old Sep 22, 2006 | 09:49 PM
to bad yours aint a 8.5" 10bolt.... i got some gears on my back seat now.. haha
Old Sep 22, 2006 | 10:35 PM
ColtSteele's Avatar
lol - dang it...
Old Sep 22, 2006 | 11:06 PM
Thanks for yall input guys!!!
looks like im goin to stick with these 3.42s...
how hard it to just replace the Diff and keep the same gears??
i have everything for a complete install. maybe i can get away with the stock pinion shims that are in there..
Old Sep 22, 2006 | 11:32 PM
hemidup's Avatar
Turbo's and high stall converters, plus 4.56 gears, do not make the best mix. We're building a 1750 hp, twin turbo 68 RR, with an old school Hemi bolted up to a custom built Turbo Glide. Turbos's love load. Period.
Old Sep 23, 2006 | 12:34 AM
ok well i have learned something new...
so the 3.42s are stayin in there. i get to replace the Gernade-80 with the Eaton LSD and go from there.
Thanks yall!
Old Sep 23, 2006 | 08:01 AM
vanillagorilla's Avatar
There has been NO mention of tire size in this thread whatsoever. Tire size it what determines the effective gear ratio. You could have 3.73" with a 27" tire and it would provide the same effective gear as 33" tires and 4.56's.
