THE Tru-Cool 40K GVW Transmission Cooler Install Thread
Old Jun 2, 2017 | 01:34 PM
  #281
ILuvJDM's Avatar
Can you use two 90s on the 4L60e or do you need a 45? I'm going to install the 40k now on my 60e but will be doing an 80e swap in a few months. I bought (4) 90s for the 80e but curious if I should get a 45 for the 60e
Old Jun 2, 2017 | 06:41 PM
  #282
bruceb58's Avatar
I used 45s for the 60E. I can't remember if 90s would work.
Old Sep 5, 2017 | 10:54 AM
  #283
MASS seller approved
For anyone that's interested, I've got specifics now how to tell if my install brackets will work with NNBS trucks.
Details here: https://www.performancetrucks.net/fo...rdware-508374/
Old Oct 14, 2017 | 07:03 PM
  #284
MikeOD's Avatar
I'm building a complete new cooler line setup for my 4L80E. Since I live in New England I want to keep the radiator cooler to warm the trans fluid on cold days.
The 5/8-18 inverted flare fittings in my brand new radiator and my old radiator have a huge washer on them that pulls the internal cooler back against the plastic end tank to seal coolant in. Have you guys that used the radiator cooler with -6 AN adapters run into this too? I honestly don't know if my old radiator was stock or a replacement as I didn't buy the truck new, but my replacement came from GM.
Old Oct 14, 2017 | 07:16 PM
  #285
MikeOD's Avatar
...I was able to remove them from my old radiator, I don't think they're 5/8-18 inverted flare. These are o-ring fittings. For what it's worth, my truck is a 2005. I think GM changed something in the design.
Old Oct 14, 2017 | 07:27 PM
  #286
MikeOD's Avatar
Found it, my radiator has these fittings https://www.summitracing.com/parts/rnb-800-619/
Has anyone ever found an adapter to convert these to -6 AN? If I find one I'll post it.
Old Oct 14, 2017 | 10:49 PM
  #287
Silverado53's Avatar
https://www.summitracing.com/parts/rus-670840
This is what I used on my 07 Tahoe's radiator cooler to run -6 AN lines
Leak free for about 30,000 miles so far
Old Oct 15, 2017 | 09:24 AM
  #288
MikeOD's Avatar
Awesome. I was wondering if -6 ORB fittings would work. Did you need a washer between the fitting and the end tank or did you just screw them in?
Old Oct 15, 2017 | 11:08 AM
  #289
Nope, I just snugged them down with an AN wrench
Old Oct 15, 2017 | 08:13 PM
  #290
MikeOD's Avatar
Awesome. Thank you very much. I'm going to do the same.
