troubles after cranking up torsion bars
Old Dec 16, 2006 | 05:22 AM
Lloyd Smale's Avatar
Default troubles after cranking up torsion bars
I have a 06 club cab 4x4 that has 285s on it and the torsion bars cranked up to clear. Ive heard that the ball joints will wear prematurely like this and its just a matter of time. As few as 5000 miles before they will be shot. How many have done this and how much trouble have you had with steering componants and how many miles have you gone with your truck with them cranked up. Thanks
Old Dec 16, 2006 | 09:47 AM
beastmode's Avatar
Import Moderator
now i dunno where you heard the 5000 miles bs from that is not true at all... the torsion bars are ADJUSTABLE, which means you have the ability to go up and down with them, ive had mine bottomed out as much as the bolts will go up for about 40,000 miles and ive NEVER had this problem. dont worry about it, word of advice though dont put the ford torsion keys on... ive heard good adn bad about em not to say they dont work for some ppl but ive had problems wit them on my blue truck personally
Old Dec 16, 2006 | 11:10 AM
budhayes3's Avatar
PT's Slowest Truck
You should have the truck aligned though after messin with the ride height...you'll be surprised how much difference a small tweak in ride height will affect steering geometry.
Old Dec 16, 2006 | 11:29 AM
1FUNZ71's Avatar
14 Second Truck Club
Old Dec 16, 2006 | 11:32 AM
beastmode's Avatar
Import Moderator
yes this is very true. that was something i put off for awhile and wore my tires terribly because of it... and as Bud said it WILL affect your steering geometry
Old Dec 16, 2006 | 12:19 PM
04BlackGmc's Avatar
10 Second Club
Idk at 39k my front end isnt the best.
Old Dec 17, 2006 | 05:53 AM
samdogmx's Avatar
8 Second Club
no problems with mine after 5000 + miles
Old Dec 17, 2006 | 10:19 AM
thunder550's Avatar
High on diesel fumes
I've had mine cranked about 1.5" for over three years and about 95K miles and I'm still running everything stock in the front except tie rod ends.
Old Dec 17, 2006 | 12:26 PM
Get it aligned after you get the T-bars adjusted to where you want the ride hidth to be at.
Jim
Old Dec 18, 2006 | 05:14 AM
I did have it aligned.
