Trans Temp Sender Location
Old Jun 2, 2007 | 11:01 PM
offz71road's Avatar
Default Trans Temp Sender Location
hey i want to install this autometer trans temp guage and from what i have read there could be clearance issues with installing the bung and sender. before i tear everything apart i want to have the unit mounted and brazed. just wanted to know where on the pan everyone has there sending unit mounted.
4l60e stock pan depth
also installing transgo HD-2 and corvette servo
2004 silverado
Thanks
Old Jun 3, 2007 | 09:30 AM
SnakeOiler's Avatar
I had mine put on the front of the pan, then I grinded down the weld smooth:
Then I painted the pan:
Old Jun 3, 2007 | 04:00 PM
thunder550's Avatar
High on diesel fumes
You can also use the pressure port on the driver's side above the shift linkage. Your sender should thread right in.
Old Jun 3, 2007 | 04:24 PM
BlackLM7's Avatar
Yep, that's what I did. I heard that location isn't the best for accurate readings but at least I have an idea of what my tranny temp is.
Old Jun 3, 2007 | 08:37 PM
SnakeOiler's Avatar
my observations show me that either place is OK.
Old Jun 4, 2007 | 12:10 AM
thunder550's Avatar
Mine too. I also have a scan gauge that reads the factory trans temp sensor and the two are pretty close, probably within about 5 degrees of eachother.
Old Jun 4, 2007 | 12:18 AM
vanillagorilla's Avatar
I've used the pressure port on several different trannys I've had.
Old Jun 4, 2007 | 01:36 PM
WJ MARK's Avatar
I drilled and tapped the pan for mine. seems to work fine right there
Old Jun 4, 2007 | 07:02 PM
offz71road's Avatar
thanks everyone for there input i appreciate it
Old Jun 5, 2007 | 10:12 AM
GMJim's Avatar
I installed a cluster with a trans temp gauge in it but I'm told this only measures cooled fluid that has returned to the pan. I'm planning on installing a Autometer gauge as well and I'm putting the sender right in the fluid out line as close to the transmission as possible. I figure the fluid on the way out represents the actual temperature inside the tranny. You can buy a manifold from Autometer to put a sender in line.
http://www.autometer.com/cat_accesso...st.aspx?pid=40
