trans slips/shudders in D but not in R
Old May 16, 2011 | 01:31 PM
SimpleManLance's Avatar
Default trans slips/shudders in D but not in R
this is my 2000 truck. brand new trans and converter, both stock. fluid is good and topped off.
truck will drive just fine in reverse but when you put it in (D) 3 2 1 it will slip/shudder as soon as you hit the gas and not move. has anyone had this problem before or know what what it could be.
Old May 17, 2011 | 12:35 AM
trxmxzx's Avatar
13 Second Truck Club
Could the shifter indicator be a problem? gm's damn glue got the best of his a few years back and cracked the case on it... now you can try to adjust the location and nothing happens in the cluster... when in park it says nothing, in reverse it- say reverse, neutral says nothing, "drive" takes a few seconds to show its in the drive gear, then after that 3rd 2nd and 1st all say its in Reverse in the custer! WTF
Now could this be a problem point? Does the computer look at this?
Old May 17, 2011 | 12:45 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
When you're power braking but the vehicle is not moving, right? Makes me think of an ignition miss.
Old May 17, 2011 | 01:38 AM
trxmxzx's Avatar
just put all back to stock form, its weird never have had this happen before, lets say you put it into "drive" you release the brake and push the throttle to about 5-10 percent the truck starts to move like normal then as soon as it feels or reads 1 mph plus it shutters like it has a 3400 stall in it.... i would take it down the road if i could get it out of my driveway- its not right. It seemed like low fluid but its not it either... i re check location of trans lines, properly ran to cooler... thinking that maybe the issue but thats correct.
Only other thought could be transfer case speed sensors... we took that apart and we could have misplaced one in the right location... 2 had the same part number the other didnt match..
i was hoping it could be something as dumb as the shifter location brain on the side of the trans... but who wants to spend $$$ if its not even the problem..
Old May 17, 2011 | 02:48 PM
anyone else with any ideas. just a heads up the truck is at TRXMXZXs he is the one that put the truck back to stock for me.
Old Jun 6, 2011 | 02:33 PM
TTT. just replaced the neutral safety switch box that bolts to the side of the trans and its still doing it. anyone have any ideas. it goes fine in reverse nut in D321 its slipping.
Old Jun 6, 2011 | 09:53 PM
Vince B's Avatar
Lance who built this ''new" trans? Why don't you take it back to them and let them fix it? If I had to guess the issue is internal and its not electrical. I would be looking at the forward accumulator or a boost valve for starters.
Old Sep 23, 2013 | 11:30 AM
trxmxzx's Avatar
a old thread** but just wanted to let anyone who has a similiar issues and was searching the forum, anyhow we found out that nelson must not have changed the pcm settings back to 4l60 from the 80e. Black bear tune different pcm works just fine now!
Texas5.3_1251
Mar 5, 2016 08:10 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
