Looking to supe up my truck
Hello, I am looking to boost my truck a little. It is a 07 1500 with a 4.8. I am thinking of buying LS376/525 gm motor. Could I use my stock trains or should I get the connect and cruise and use that trans. For 525 hp, I'm assuming I'm going to need to beef up the rear. Should I do the control arms while at it? Thanks.
The only difference is the cam. You are paying a higher price for just the ASA cam, a cam meant for a 17 year old spec LS1 engine with cathedral port heads meant for short track racing. Cam lobe tech has come a long way in the last 17 years with much better designs available now especially for square port LS3 heads. Spend less money on the base LS3 crate engine and put a better aftermarket cam and springs in it if you are wanting more power than the stock LS3 has.
Since it's a nnbs, would a ls3 fit with my stock harness? Shoud I get the ECM that summit offers? http://www.summitracing.com/parts/nal-19259261
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Nimoryan
Jul 5, 2015 03:50 PM
