tourqe converter
Old Nov 24, 2007 | 09:54 AM
ecmoney's Avatar
Default tourqe converter
this is probably a dumb question but exacty how do tc's work. if its a 3200 stall does that mean it will not move at all until 3200 rpm's. any help would be appreciated.
Old Nov 24, 2007 | 09:58 AM
02silvy's Avatar
it will move but it will feel like the trans is slipping until the specified stall speed. and when its to the floor when it shifts it wont or shouldnt drop below the stall speed. it basically keeps your motor in its powerband
Old Nov 24, 2007 | 10:09 AM
ecmoney's Avatar
so for everday driving it wouldnt be too comfortable at around 3200. i am thinkin maybe like a 26 or 2800 stall. but i like a aggressive running truck so i just dont know if i need to just go with the 3200. i have never ran a diff stall so i am not sure on what to go with
Old Nov 24, 2007 | 11:15 AM
Slow91z's Avatar
the less power you are making the less the stall speed...at part throttle it should only feel alittle looser then a stock converter...I have a 3200 in my Turbo Buick and it feels fine driving it around.
Old Nov 24, 2007 | 11:28 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
It's not as bad as it sounds. Converters will flash stall (when you just floor it from a stop) to a higher rpm than when brake stalled. Certain mfg's converters are 'tighter' than other's (how much it grabs at partial throttle).
A converter should be matched to a cam but even a stock cammed truck will benefit with a 3000 rpm stall. I wouldn't go much higher if planning to tow or haul very much and don't forget to install a quality aftermarket transmission cooler.
Old Nov 24, 2007 | 11:31 AM
ecmoney's Avatar
thank you .... i think i will want a somewhat loose 3000 or 3200 stall
Old Nov 24, 2007 | 11:35 AM
ecmoney's Avatar
i mean a somewhat tighter stall i think, because i do tow ski boats from time to time
Old Nov 24, 2007 | 11:55 AM
SlvrSierra4.8's Avatar
Look into the Yank tt3000. Can still tow, good driveability, and are tighter than most 3000 stall convertors. PM Sent
Old Nov 24, 2007 | 03:45 PM
nonnieselman's Avatar
I love my TT3000!!! driveability is great..... expect about 800rpms above the stock converter around town and if you are gettin on the on ramp or somthing you will see 2200 or so.. Mine flashes to 4000 when towing a trailer in boost...
Old Nov 24, 2007 | 08:30 PM
02silvy's Avatar
like trevor1t said install an aftermarket cooler because driving with the stall on the street does make the tranny a lil hotter than stock convertors would. and put a shift kit in if you havent already. itll def. be fun then
