TBSS AWD Front drive shaft spins no movement
Old Nov 25, 2012 | 03:17 PM
LIL SS's Avatar
Default TBSS AWD Front drive shaft spins no movement
Last week I posted that I thought I might have lost the trans in the TBSS. I put it on 4 ramps today and had a buddy watch the drive shafts in gear. The front drive shaft spins as soon as it is put in gear and does not stop until put back in to park. It is grinding like the pinion in the dif is stripped.
I am not sure how the AWD system transfers power between front and rear. So I am leaning towards the front dif being gone.
Being an AWD, would I have any movement of the vehicle if the front dif is broke?
Are there any write-ups on removing the front dif?
Any help would be greatly appreciated.
Shaun
Old Nov 25, 2012 | 03:31 PM
03sierraslt's Avatar
Did we ever determine exactly what transfer case is in that? Once we know exactly what case it is then we can figure out what its properties are. Personally I would think it would try to put power to the rear but...... not sure.
Old Nov 25, 2012 | 04:20 PM
1994Vmax's Avatar
This is probably a good read for you LIL SS.....
Failure of Splines in Front Axle Assembly - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
It appears you are in dead in the water if the the front shaft just spins. So your t-case and trans are probably just fine.
Old Nov 25, 2012 | 04:56 PM
Wow, that was a interesting read. Thanks for the info 1994Vmax
Old Nov 25, 2012 | 07:42 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Should be NVG 120 under the RPO NR9
Uses a T3 Torsen unit instead of a viscous coupler.
Torsen T3 Unit - Info From Torsen Techs - Page 2 - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Old Nov 25, 2012 | 11:12 PM
LIL SS's Avatar
Thanks.. Now if I could only read more than just page 1.. Just registered there but looks like I need to wait a little while to get full access
Old Nov 25, 2012 | 11:45 PM
1FastBrick's Avatar
There is lots of helpful info specific to the TBSS on that site so I think you will enjoy reading up on some of the stuff.
Old Nov 26, 2012 | 10:37 PM
LIL SS's Avatar
24hrs and the mods still haven't approved me. Can't even see the first page of the thread now.. Going by super73 over there if anyone felt like sending an e-mail to a moderator for me. Rainy season is coming here and i need to get this back on the road for the wife. Thanks in advance.
Old Nov 27, 2012 | 12:33 AM
1FastBrick's Avatar
Sent a PM for you.
Old Nov 27, 2012 | 12:36 AM
Brian68's Avatar
Not completely sure about the SS trucks, but all the others had an intermediate shaft assembly on the right side that sheared on a regular basis. Easy fix, take the right front half-shaft out and the housing comes out in one piece with 3 or 4 bolts. Rebuild it on your garage bench, the dealer should keep parts for them since it is a common repair.
