stock LSD?
Old Aug 22, 2008 | 03:30 AM
nemmarick's Avatar
Default stock LSD?
may very well be a newb question but heres the deal.... ive never done a brake stand in my truck until yesturday, but when i was done engulfing the neighborhood with that lovely scent of victory, i noticed there was not 1 but 2 black strips of rubber laid down for entire burnout. how was i catchin posi? is there a stock LSD?
Old Aug 22, 2008 | 09:07 AM
KevinF56's Avatar
Yes there is. Look in your glove box at the RPO codes. If you see the code G80, you have the stock locking differential. If you don't, well sometimes open differentials can spin posi.
Old Aug 22, 2008 | 10:20 AM
nemmarick's Avatar
yeah theres a G80 code, does this mean i can return the eaton lsd? is the stock lockin diff good enuff? if so ill return the eaton and get the YANK 3200 stall
Old Aug 22, 2008 | 10:25 AM
Stoichiometric's Avatar
I would replace the g80 with the Eaton anyway. The g80 is prone to failure, which will often take out the ring and pinion.
Old Aug 22, 2008 | 01:37 PM
KevinF56's Avatar
Old Aug 22, 2008 | 07:08 PM
nemmarick's Avatar
think it couldnt handle only 5psi? i plan on just 5psi for about a year
Old Aug 22, 2008 | 07:34 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The stock unit is famous for blowing up. If you are going do burnouts or hard starts you are running a risk. Even in a stocktruck.
Old Aug 22, 2008 | 08:14 PM
InchUp's Avatar
Originally Posted by trever1t
The stock unit is famous for blowing up....
Shoulda finished this sentence.
The stock unit is famous for blowing up BECAUSE forums are littered with carnage pictures of how little Johnny opened up the diff cover to find chunks falling out when his G80 grenade went boom. You're not going to hear any headlines starting with "Well little Johnny made it to school today, then came home. Stay tuned 'till next week...."
People love disaster pics, that's why there are so many of them on the boards. Think about how many stock G80's are out on the road, literally millions, I'd bet, all holding up to daily driving and the occasional lead foot. GM wouldn't put something into a rear end and then back it up with a warranty if they planned to replace it all the time, that's just not smart financial planning by the bean counters. They designed a true truck's differential to give open differentiation of the rear tires to help aid in gas mileage and city/towing navigation, while offering a strong mechanical locking mechanism to limit slip by either tire. Once a difference of 500 rpms is felt, the cam-ramps automatically lock in place and now you have a locked rear. 50/50 split of the power, just what you need to get out of that ditch or up and over a log in the back country.
When you start getting stupid with anything, of course it will break especially if it wasn't designed to take the abuse you're throwing at it. If you want to play, pay for it. If you plan to brake stand, launch hard, smoke the tires and increase horsepower above that of a stock or slightly modified factory setup, upgrade. Duh. Any of the aftermarket gear-type limited slips will work, so pick your flavor.
Old Aug 22, 2008 | 08:22 PM
trever1t's Avatar
this is absolutely true....but you only quoted the first part of my post I did say if he planned on doing burnouts etc. Yes, my last truck had a G80 and it performed ok...but my gear guy has a wall full of grenaded diffs too
Old Aug 22, 2008 | 09:31 PM
nemmarick's Avatar
well thanks for the input, i think i will keep and install the eaton, but maybe just maybe first....i will add to the grenaded diff shrapnel wall of fame
thunder550
Oct 8, 2015 04:53 PM
OLD BULL
Aug 1, 2015 05:00 PM
lxcoupe
Jul 30, 2015 02:42 PM
lxcoupe
Jul 21, 2015 02:12 AM
Chiphead
Jul 13, 2015 10:16 PM
