Replacing front hub/wheel bearing
Old Apr 18, 2012 | 11:00 AM
SmokinHot98's Avatar
Default Replacing front hub/wheel bearing
How simple is it to change on these trucks? It's the truck in my sig. 2004 2wd, my driverside bearing is bad just want to get a scope of the work
Old Apr 18, 2012 | 11:19 AM
Whitecrewcab's Avatar
It's simple, jack it up, yank the wheel off, take off the caliper and mounting bracket, remove the disc, unplug the ABS and take out the mounting bolts. Reverse procedure and be done. Should only take you about 30 minutes even if you have never done one if you have done any mechanicing before.
Old Apr 18, 2012 | 11:39 AM
rroutlaw's Avatar
+1 to what whitecrewcab said. Only thing I would add is to make sure you have a breaker bar because those bolts that hold the hub and bearing assembly to the knuckle have factory loctite on them and can be a pain to remove without the breaker bar
Old Apr 18, 2012 | 11:42 AM
TX Tahoe Z71's Avatar
Not too hard, just did mine last week. Spray some PB Blaster on the bolts and let it soak for 15-30 minutes as they can be tough to break free the first time. Remember the order everything comes off as it's easy to put things back on out of order, then you have to pull everything off again.
Old Apr 18, 2012 | 11:56 AM
RYNO63SS's Avatar
Yeah those caliper bolts are on there good! I could not get them with a breaker bar alone, I had to get some heat on it too.
Old Apr 18, 2012 | 12:21 PM
nonnieselman's Avatar
the caliper bracket bolts and the hub bolts are on there good.
and the hub could have some rust build up on the knuckle.. i had to use a hammer to get my driver side one off.
its a easy job.
Old Apr 18, 2012 | 08:25 PM
SnakeOiler's Avatar
Just as everyone has said, all bolts are very accessible, but could be on tight. Easy job.
Old Apr 19, 2012 | 02:56 AM
awesome thanks guys!
5.3Caprice
Nov 7, 2015 08:56 PM
AUTOT3K
Aug 16, 2015 06:21 PM
Oobray
Aug 12, 2015 10:56 AM
Ketis
Jul 23, 2015 12:37 PM
