Rear gear swap in a 4X4, do I change the front as well.
Old Jul 15, 2010 | 08:15 PM
Pray's Avatar
Default Rear gear swap in a 4X4, do I change the front as well.
I wan't to put 4.10's in my 06' ECSB Silverado 1500 Z71. A buddy of mine said I would have to change the front gears to match if I want to ever use my 4wd. I have 3.42's currently in the back and I don't know what up front. What do I really have to do? This is my first truck so I am lost with the 4wd stuff. It won't be cost effective if I have to change the front and rear gears.
Thanks guys.
Old Jul 15, 2010 | 08:30 PM
budhayes3's Avatar
PT's Slowest Truck
Yes, the front and rear gears must be the same, so you will have to replace the fronts as well
Old Jul 15, 2010 | 08:32 PM
Pray's Avatar
Well, that sucks. Thanks for the info. You just saved me a bunch of money. I will just use that money to build a bigger motor.
Old Jul 15, 2010 | 10:04 PM
fredkj3's Avatar
you dont have to as long as you never put it in 4wd except in mudd... hahahahah..
im jk dont do that... replace both or none
Old Jul 17, 2010 | 12:03 PM
Country Boy's Avatar
Senior Member
no, you do not have to do the front. Just remove the front D-shaft so you dont accidently put it in 4wd.
Old Jul 17, 2010 | 12:36 PM
1LOW4X4's Avatar
Banned
yeah you can remove the front driveshaft and you wont have to. But I hate having a 4x4 with no 4x4 capabilities.
I thought all 4x4's had some sort of G80-posi in them?
Old Jul 17, 2010 | 04:50 PM
HoveyBayou's Avatar
Mine has 4.56s in the rear and 3.73s in the front with the driveshaft in. It is just temporary though. Only thing it will make it do is turn the ABS and BRAKE like on.
Old Jul 18, 2010 | 01:40 PM
fredkj3's Avatar
yea it will work as long as you dont put it 4wd.... and also when the ABS light is on you wont have ABS...
Old Jul 18, 2010 | 01:42 PM
fredkj3's Avatar
that would be sweet to have if you could disengage the rear driveshaft.. and then you could have highway gears in front and towing/racing gears out back.. and swap between them
Old Jul 18, 2010 | 07:00 PM
Beatdown Z's Avatar
Laid Back
Hmmm...twin-sticked NP205?
