question about a 2/4 drop with exhaust goin over axle
Old Mar 14, 2006 | 09:14 AM
dry_kill's Avatar
Default question about a 2/4 drop with exhaust goin over axle
Well I'm going to be putting a sts rear mount turbo on my truck, my current exhaust is a flowmaster dual outlet going over the axle and exiting out the back of the truck, I had 2 inch drop shackles put in about a month ago and ever since, when I hit a big bump, the pipes hit the axle, now my question is, if I do a 2/4 drop, will I be able to still run the pipe over the axle or will I have to keep it the height it is for the turbo? Thx
Old Mar 14, 2006 | 09:21 AM
leochevy2001's Avatar
a lot of aftermarket cat-back exhaust systems can handle a 2/4 drop so you should have plenty of room. you will need to have the pipes run a little higher over the axle.
Old Mar 14, 2006 | 02:50 PM
02BlueStepside's Avatar
It won't work with a 4/6 I know that. With a 2/4 you shouldn't have a problem. What type of exhaust/tip does the sts kit come with? If it doesn't come with anything just have the exhaust shop tuck it up tight so there is enough axle travel.
Old Mar 14, 2006 | 03:28 PM
CurtD's Avatar
10 Second Truck Club
I've got a 2/4 drop with 4" over the axle and it don't hit.
Old Mar 14, 2006 | 07:09 PM
dry_kill's Avatar
I believe its just a pipe coming out the turbine, but the full turbo is going to be assembled after the axle, but I don't know what's gunna happen now, the guy that is selling it to us is going back on his word so I have to see what happens
5.3Caprice
Nov 7, 2015 08:56 PM
thunder550
Oct 8, 2015 04:53 PM
USMCvet0311
Aug 1, 2015 07:45 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
KleanKustoms
Jul 18, 2015 10:08 PM
