Pinion angle WAY off after Belltech 4" rear drop install...
Old Apr 29, 2019 | 07:18 PM
10 Second Club
Default Pinion angle WAY off after Belltech 4" rear drop install...
I did install the supplied pinion shims, still not even close. I see that 6 and 8 degree shims are available. Has anyone else had this issue? The pinion literally points upwards towards the bed floor. Just to clarify, this is a shackle/hanger kit.
Old Apr 29, 2019 | 07:37 PM
FFDP's Avatar
I did 6 degree shims when I did front hangers and rear shackles on my 2006 single cab long bed.
Do some measurements and see what you will need.
Old Apr 29, 2019 | 07:53 PM
10 Second Club
I believe my kit came with 3 degree shims? Maybe 2. Right now, I am at 0 when I measure from both ends of the driveshaft. If I stick the angle finder on the bottom of the housing, it reads about 12 degrees. The amount that the pinion is tilted upwards is extreme. I have not driven it for fear of damaging something.
Old Apr 29, 2019 | 09:31 PM
FFDP's Avatar
I believe I measured on the yoke(s) itself. I rotated each end to get the flat side down on each. Sometimes a spacer is needed to clear the driveshaft using a bigger angle finder.
I didn't stick the angle finder on the housing itself.
Like this picture.
Old Apr 30, 2019 | 05:59 AM
madmann26's Avatar
SC or Xcab?
Old Apr 30, 2019 | 12:55 PM
10 Second Club
Originally Posted by madmann26
SC or Xcab?
It is a regular cab, short bed.
Old Apr 30, 2019 | 03:24 PM
madmann26's Avatar
With my DJM flipkit, I still had to use a 2-degree shin and adjust my center support bearing before I could get all the noise out of mine.
Old May 1, 2019 | 05:23 AM
RySmDPT14's Avatar
if you are able, get the blocks that have an angle built into them.
Old May 4, 2019 | 02:57 PM
10 Second Club
I am an R-tard. I kept thinking about this, and looking under the truck... I had the shims in backwards. Fat end towards the back of the truck. I flipped them around a few minutes ago, viola! -2 pinion angle now. I ordered 6 degree shims just in case. I'll drive the truck on the highway after I have it aligned, see how it feels. Hopefully ZERO vibration.
walledition
Feb 3, 2016 09:54 AM
RickLowpez
Aug 26, 2009 03:09 AM
RickLowpez
Aug 7, 2009 01:20 AM
FastCrewCab4x4
Nov 15, 2006 11:35 PM
O3GMC
Dec 21, 2004 02:57 PM
