Performabuilt level 3 60e
Old May 2, 2009 | 11:52 AM
  #31
GMCtrk's Avatar
Originally Posted by getonit
If built right they can hold decent power. Look at casper08- mid 10's, pittman-11.1x, La redandready 11.0 on a 150 shot just about all the rgv guys running 11's are on 60e's and a few are in the 10's
correct me if I'm wrong, but those are all reg cabs.
Old May 2, 2009 | 03:08 PM
  #32
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Originally Posted by GMCtrk
How long have you had that performabuilt in? I want longterm results. I think the general consensus is that even the best built 60e's will eventually fail in the mid 11s @ 5000lbs. 4l80e goes into the 10s with a shift kit.
Really I think in HIGH PERFORMANCE any trans built by anyone will fail eventually. And any type will fail. The trick is how long and how many hard passes can you make first.and what makes the most sense economically and is still pratical.
Even the 80E fails I see a couple or three a month posted here and more in other places. When you consider the numbers. They probably are not so far off. There are I venture to say many more 100s of trucks with the 6xe than there 80e units.
Its really interesting people say you hardley ever hear of and 80e or a 400 failing or even a 350. Theres good reason. There are not that many of them out there. If for instance you read that 10 4l60e trans failed in a week(stock built whatever) and only see 1 80e posted as broken. The appearance would be the 80e had a better life expectancy. But what you dont see is there are 100 60e for every 1 4l80e out there in trucks so from what I can see the real failure rate is not so different.
Not to say the 80e is not stronger it certainly is and once over a certain power if practical it should be considered.
But when it comes down to it and I learned this as a kid from and old racer. If you play you are going to break ****. You use the best parts and know how you can so it will hold up as long as possible. But ultimatley wether its the trans or the drivesahft or the rear or the axles. Whatever if you run it enough times and continue to make more and more power over and over at some point somethings gonna give.
The old guys quote to me was "IF YOU PLAY YOUR GONNA BREAK STUFF. IF YOU BREAK STUFF YOUR GONNA PAY. IF YOU DONT WANNA PAY THEN DONT PLAY THE GAME"
He used to run street cars and full out dragsters the dragsters had to come apart every week to be checked and things replaced. He said its part of the game.
When I was a kid people complained about breaking there 350s and 400s all the time it seemed but back then they were the most common
Old May 2, 2009 | 03:15 PM
  #33
GMCtrk's Avatar
Good post Frank, you raise several valid points.
Old May 3, 2009 | 08:11 AM
  #34
2ktransam's Avatar
I agree with Frank that any tranny is probably going to break if you keep pushing them. If I wasn't 4wd and already have the Level 3 I would have already gone to an 80e. I will be going to a built 80e eventually but I don't have the time or $$$ right now to do it. Hopefully the L3 will hold into the mid to low 11's so I can get kicked out of the track at least once and I will be happy with my setup. Once my truck runs a sub 11.5 I am going to switch back to my TA and see if I can get it to run mid 10's with an auto swap.
Old May 5, 2009 | 09:22 AM
  #35
getonit's Avatar
Good post frank that is what I was getting at cause I have seen several people have to rebuild 80e's. The 60 or 80 can break at any given day but you always here about 60s cause they are more of them. I have seen on here that several 80's broke and local people have broke them. You play, you pay!!!
06droppedcrew
Nov 17, 2015 10:56 PM
cheyenne383
Nov 13, 2015 09:24 AM
GM1697
Oct 3, 2015 11:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
twake_410
Sep 21, 2015 10:36 AM
