Official A4 to M6 (T-56) Thread!
Old Mar 22, 2012 | 06:17 AM
  #991
DAH32's Avatar
Originally Posted by harley1247
Has any one ever put a ls2 gto and a t 56 in a silverado ?
I was, at the time there was not enough information out there about the difference in the cam sensor....I think now there is a adapter that can be used...you would be better off with a 6.0 in a truck since it is heavy and needs torque.
Old Apr 4, 2012 | 01:00 AM
  #992
Ferocity02's Avatar
Has anyone gotten the reverse lockout solenoid to work when going from auto to T56? If so, how does one go about wiring it up?
Old Apr 4, 2012 | 08:01 AM
  #993
xx_ED_xx's Avatar
reverse lock out just needs power and ground i used a push button and mounted it near the e brake. push and hold to put in reverse
Old Apr 4, 2012 | 10:16 AM
  #994
Ferocity02's Avatar
Silverado_SS_04 wired his into the brake light, seems like a simple and effective solution
Old Apr 4, 2012 | 11:21 AM
  #995
xx_ED_xx's Avatar
Until you are on the freeway slowing down to put it into 5th gear and end up grinding reverse at 80 mph...
Old Apr 4, 2012 | 11:27 AM
  #996
Ferocity02's Avatar
Ah I was thinking reverse was over and down not over and up.
Old Apr 15, 2012 | 09:23 PM
  #997
Ferocity02's Avatar
Will my stock extended cab 2-piece 4L60E driveshaft be the correct length for the f-body T56?
Old Apr 15, 2012 | 09:25 PM
  #998
xx_ED_xx's Avatar
It should be, easiest way to check is measure trans with bell housing and compare to what you have
Old Apr 15, 2012 | 10:36 PM
  #999
kren7604's Avatar
Not sure about the 2-piece driveshaft but on my 04 RCSB driveshaft I had to shorten the driveshaft 3" from 61" down to 58", to fit the t-56
Old Apr 15, 2012 | 10:44 PM
  #1000
xx_ED_xx's Avatar
Was yours an auto or 5 speed
