Official A4 to M6 (T-56) Thread!
Old Jan 9, 2008 | 12:54 PM
  #491
absmith's Avatar
I live in CT and toured the Callaway factory recently for a SAE event. Callaway is known for their Corvette projects but I got a sneak peak of one of their lesser known projects while there:
A 6spd manual conversion for the 4WD Chevy Tahoe
This involded a completely new tail shaft casting for the 6 spd manual transmission to link it with the transfer case, use of an off the shelf bell housing and clutch, a pedal assembly from the silverado (I think), and integrating the shifter into the center consol. I asked if that system would work with my LS2 TBSS and they thought it would, except for the center consol pieces. I don't have the extra cash to try this out, but if some of you are really interested it might be worth your while to give Callaway a call and see what they can do for you. They like it when one of their engineering developments can get multiple uses...
http://www.callawaycars.com/
Good luck
I ran across this post on trailvoy.com. It sounds like there may be a solution to mating the T-56 to a transfer case.
Old Jan 26, 2008 | 04:50 AM
  #492
Tavenner13's Avatar
I just read this entire thread word for word, taking my own notes as needed. i started at 1:13AM and its now 4:50AM. I wish I could study for school this easily!
HUGE props to everyone involved in this thread.
Old Jan 26, 2008 | 01:37 PM
  #493
04GIBBS's Avatar
Wish you luck my man. Give me a shoutout if you need anything
Old Feb 3, 2008 | 07:04 PM
  #494
sowaidi's Avatar
thanx for the post guys
this should be a STICKY
Old Feb 3, 2008 | 08:14 PM
  #495
TURBHOE's Avatar
no stink'n t56 for me.
Old Feb 13, 2008 | 03:14 PM
  #496
what harness do i need to do the wiring? the clutch switch off a fbody? the stealership came up with a million different ones for a 6 speed. they were no help.
Old Feb 13, 2008 | 03:15 PM
  #497
i read through all the wiring stuff yall talked about but noone ever says what connector it is or maybe a part number or something
Old Feb 15, 2008 | 07:37 PM
  #498
Regency04's Avatar
Anybody ever try this with an actual viper t56? I got a 5 speed now and i bought a viper t56 and a ls1 bell housing.
Old Feb 15, 2008 | 07:42 PM
  #499
TURBHOE's Avatar
you have to change the front plate to a ls1 front plate according to the people i was going to get mine from. the shift also sits further forward tan the ls1 version. other than that the mount is about the same place just a hair off. i was going to use the viper t56 but i'm not gonna get to do it at all now. i can give you contact info on the people to get ahold of if you want.
Old Feb 15, 2008 | 07:45 PM
  #500
TURBHOE's Avatar
the clutch pedal switch from a 5speed truck. the auto wireing is on the trans. the black box is on the side of the trans where the gear shifter connects. then the speed sensors is on the tail.
