now its REALLY 4L80E time, please help
Old Sep 28, 2012 | 12:51 AM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
Some guys don't like the TG plate because it's 3 piece's and has a tendency to cross leak. I am guessing part of that is because they don't line up right like you have shown in the picture.
Old Sep 28, 2012 | 12:58 AM
  #22
Camaro Zach's Avatar
Originally Posted by walledition
(4) where can i put the sensor for the trans temp? i see it doesnt have the same port as the 60E has
Thank you for your help
Front speed sensor almost points straight to the test port you can run your temp sensor in (just like the 60e) The port is just above the NSS, you can see it in one of your above pics.
Old Sep 28, 2012 | 07:02 AM
  #23
Vince B's Avatar
I've never noticed the check ball holes being that far off. Are you sure that you lined up the alignment holes properly? For the record I would not modify the hole where the check ball has to seat. This would be a big mistake. I can see where some of the holes might be a in a slightly different location but as long as the factory gaskets do not block any of the holes then you will be fine.
Old Sep 28, 2012 | 09:58 AM
  #24
walledition's Avatar
would u recommend just using the stock plate then? in that case what would i have to do, just drill the holes bigger on the stock one and im ready to use it?
Old Sep 28, 2012 | 10:32 AM
  #25
VegasJ's Avatar
Jesus. Scary to see what I have to look forward to...
Old Sep 28, 2012 | 02:20 PM
  #26
Originally Posted by black04
I just drilled them like the instructions said.
Could also do like a aeroforce scangauge or something to monitor trans temp. Thats what i have in my truck.
i have an autometer gauge i used in my 4l60e, actually this picture is taken from the 4l60e, u can see the sensor there, i just need to know how i can use the same lil sensor in the 4l80e
Old Sep 28, 2012 | 02:53 PM
  #27
slow67's Avatar
Gingervitis Addict
Yes, the pressure test port on the 4L80E is also 1/4 NPT. It will read a little higher than actual temp, since its basically measuring case temp instead of fluid temp.
Old Sep 28, 2012 | 02:55 PM
  #28
thats weird i checked the 4l80e yesturday and couldnt find it, iŽll look at it again later, thank you
Old Sep 28, 2012 | 05:50 PM
  #29
slow67's Avatar
Gingervitis Addict
It's roughly in the same location as well.
Old Sep 28, 2012 | 06:52 PM
  #30
smokeshow's Avatar
Mod with training wheels
If you want to use the stock plate, follow what BlackGMC and VinceB said in this thread:
https://www.performancetrucks.net/fo...t-drum-506779/
My trans is working great with that method
