now its REALLY 4L80E time, please help
Old Nov 11, 2012 | 10:54 PM
  #41
black04's Avatar
Set P2761 to "No error reported" and you will have lock up. Not sure about the generator codes.
EDIT: Disregard this thought you were running the 4L60e tune with the relay mod.
Old Nov 11, 2012 | 11:28 PM
  #42
walledition's Avatar
can u tell me a lil more how to do this? i dont have my truck near me right now but if u tell me the steps iŽll do it first thing tomorow
thank you
Nevermind found it, ill let i know what happends tomorow thank you
Old Nov 12, 2012 | 12:25 AM
  #43
black04's Avatar
Yup just change it in the drop down list in editor under Engine Diagnostics > DTCs
Old Nov 12, 2012 | 02:47 PM
  #44
well still no lock up, i did what black04 said and now i dont get that DTC but still no lock up
any other ideas?
Old Nov 13, 2012 | 03:34 PM
  #45
update!!!! and this time a good update
these 2 generator codes are there because tuner sent me a 2004 file instead of an 2005, i found out swapping back to my old tune and they where gone, so i turned does codes off and everything seems normal
[PCM] P0622 - Generator F-Terminal Circuit (Pending) (Old) (History) (Current) (Immature)
[PCM] P1637 - Generator L-Terminal Circuit (Pending) (Old) (History) (Current) (Immature)
and about this code:
[PCM] P2761 - Torque Converter Clutch Pressure Control Solenoid Control Circuit/Open (Pending) (Old) (Current) (Immature)
i had changed the beige wire instead of the brown wire in the round connector at the transmission
so i have no codes now and i have lockup
i still have a leak at the round connector (ive been reading its a common problem), iŽll change the harness and i should be ready for the bracket racing this weekend
Old Nov 13, 2012 | 11:21 PM
  #46
went to a transmission shop and bought a used good condition harness, took everything apart to find out the last connector is different on the harness i bought
the harness my transmission came with:
the harness i bought:
only one connector is different, iŽll see if i can change it tomorrow
i wonder what the difference is, year i guess but from what year to what year is each conector
Old Nov 14, 2012 | 05:45 AM
  #47
Vince B's Avatar
The used harness you bought is an 04 and up harness. The one you originally had is one that can be used in 91-03 units using the correct epc solenoid. With either harness the fix would be to get the correct epc solenoid to match the harness. In your case you will either have to get the correct early harness or add the late epc solenoid.
Old Nov 14, 2012 | 09:27 AM
  #48
is it easy to change the solenoid?
Old Nov 14, 2012 | 12:43 PM
  #49
Vince B's Avatar
Yes its just one bolt. Just make sure to put the new solenoid in with the braket in the same location. Pay close attention to this before removing it and you should be fine.
Old Nov 14, 2012 | 02:44 PM
  #50
thank you! i got another harness, iŽll install it tonight and update you
