now its REALLY 4L80E time, please help
#21
Some guys don't like the TG plate because it's 3 piece's and has a tendency to cross leak. I am guessing part of that is because they don't line up right like you have shown in the picture.
#22
Front speed sensor almost points straight to the test port you can run your temp sensor in (just like the 60e) The port is just above the NSS, you can see it in one of your above pics.
#23
I've never noticed the check ball holes being that far off. Are you sure that you lined up the alignment holes properly? For the record I would not modify the hole where the check ball has to seat. This would be a big mistake. I can see where some of the holes might be a in a slightly different location but as long as the factory gaskets do not block any of the holes then you will be fine.
#27
Yes, the pressure test port on the 4L80E is also 1/4 NPT. It will read a little higher than actual temp, since its basically measuring case temp instead of fluid temp.
#30
https://www.performancetrucks.net/fo...t-drum-506779/
My trans is working great with that method
