lil dilema...
Old Apr 12, 2006 | 08:40 PM
freightdriver's Avatar
Default lil dilema...
in afew months i'll be buying an 06 rcsb can't decide wether to do 2 wheel or go ahead and get the 4x4. if i get the 4x4 i'll be lowering it with spindles and alil torsion bar uncrank... if the 2wd i'll be puttin a 4/7 or so on it.
i'm wanting to put a s/c on it later this year and after the warranty runs out building a 6.3 stroker... so with how much power i'll be running i'm not quite sure what i want if i get the 4x4 i'll be swappin in an awd case and 4l80e
if i get a 2wd i'll be swapping in a 4l80e and whatever axle i'll need to handle the power.. will the rear hook up if i we're to run 4 link and coilovers? also i won't be running much more than a 12 wide tire.
Old Apr 12, 2006 | 09:56 PM
nichoms's Avatar
i like the 2 wheel drive, i think some 4x4's look goofy lowered, but i say do whatever you want to man.
Old Apr 12, 2006 | 10:02 PM
dirt track racer 81's Avatar
unless you do alot of offroadin id go for the 2 wheel drive..alot lighter, but its all up to you
Old Apr 13, 2006 | 02:02 AM
2wd, 4wheel IMO would be a waste if you are lowering it anyways and doing all that swapping
Old Apr 13, 2006 | 02:46 AM
F8L Z71's Avatar
For street racing the 4wd would pwn! True its heavier but 98% of the time you wont have slicks on the truck and wont be able to launch for crap. Its more expensive but if done right it would ge awesome IMO.
Old Apr 13, 2006 | 09:51 AM
smooth sierra's Avatar
If you plan to lower a 4x4 that much be prepared for problems with your cv joints on the front axles. The slightest change in angle can have drastic effects.
I would go with the 2wd with some good traction bars or 4 link it and it will hook plenty good.
Old Apr 13, 2006 | 10:10 AM
Post
I've heard that (starting from the AWD SS's O.E. ride hidth) that 2" is all you they can be lowered down to in the front. Why not just buy a SS or a Vortec Maxx eddition Silverado? I know they cost a little more, but if a lot of power is what your after, the LQ9 6.0L would be a great starting point.
Jim
Old Apr 13, 2006 | 10:17 AM
Nick™'s Avatar
he wants a RCSB, can't get those in that configuration
Old Apr 13, 2006 | 10:32 AM
SSlow 4.8's Avatar
exactly... or you can wait till 07 But these next 6 months or so untill they come out will feel like an eternity since it sounds like your ready to do it now, lol.
Old Apr 13, 2006 | 10:40 AM
Post
Oh, I didn't read that part. Then in that case, the part about the lowering the 4x4 version still applies to my post. The SS or Vortec Maxx eddition Silverados will not be of choice then.
It really will ball down to where you live and how you will be using this truck.
If you live where is snows go with a 4x4. If it doesn't snow and you will only stay on the concrete, go with a 2wd and build up the rear end for traction.
You can use a locker w/ 3.73 gears, Caltracs, and a spare set of drag tires & wheels. That will get a 2wd to hook quite well.
If you go the 4x4 route, just be carefull how much you lower the truck down to.
Jim
denalircsb
Dec 21, 2020 09:04 AM
thompson
Dec 27, 2017 06:48 AM
sTNT971
Sep 26, 2015 04:22 PM
97_ek
Sep 23, 2015 09:16 PM
lawhitediamante
Aug 12, 2015 12:14 PM
