Lets talk 6l80!!!!
#84
Thats actually a 6l90 converter... Need make sue uts got the right spline count, some of the 6l90s have, a different input shaft. Dont remember spline counts off top of my head but when i was looking through the transtar converter catalog there was a differnce in spline count between 6l80/90.... I wouldnt be oposed to a dacco converter either, they usually go through them and update them when they remanufacture them... And i have never had an issue with a dacco converter!! And for 150/w core charge, cant beat it!!!
#87
Interestingly, i got to reading the little instruction sheet that came with my output shaft, they have updated the output shaft to eliminate the 2 ring gears and spacer and 2 snap rings to a solid ring gear hub for the output shaft assembly, and redesigned the output shaft sensor to solid lugs rather than holes....
#88
Anybody have the part number for the output shaft seal, the one in the seal kit i have is for the transfer case/slip yoke!! I need the 4wd/vette seal that goes into the back of the case...
#90
The one in the old drum was and could see the cracked weld in the back of it, but my "new" low mileage take out was fine... Could have probably run the drum the way it was but i figure while i am in there....
