Lets talk 6l80!!!!
Old Jun 30, 2016 | 06:25 PM
  #61
07Softail's Avatar
I made the 3-5-R drum holder from a pair of old Vice grip clamps and a steel band. and I use a large worm clamp for pump alignment same as 4l80 tool. It works perfect and cost $3.00 at the hardware store.
RT
Old Jun 30, 2016 | 06:28 PM
  #62
Wolftrk99's Avatar
Didnt realize with the step in the pump that would work... Wonder now how muchbigger the 6l80 pump cover is than the 4l60
Old Jun 30, 2016 | 07:35 PM
  #63
07Softail's Avatar
doesn't look much bigger, but I honestly haven't measured one either. BTW I have used a stick of tig wire to hold the 3-5-R Drum assembly while easing it down.
RT
Old Jun 30, 2016 | 07:40 PM
  #64
Wolftrk99's Avatar
Lol that redneck ingenuity at it finest...
Old Jun 30, 2016 | 07:44 PM
  #65
07Softail's Avatar
Hell yeah!!! LMAO! I would also recommend anyone that goes into these transmissions to pull the pressure relief spring and ball out and re-seat the ball with a brass drift punch. Re-seating it provides more precise pressure relief from what the spring is rated for. I have seen a couple of seats nicked from the machining process which would let fluid bleed off earlier than it should.
RT
Old Jun 30, 2016 | 08:11 PM
  #66
Wolftrk99's Avatar
Oh you mean the one gm soecifically tells you not to mess with, lol
Old Jun 30, 2016 | 09:48 PM
  #67
07Softail's Avatar
I guess.... it's in the pump cover. it's between the TCC control valve and the converter feed limit valve.
RT
Old Jun 30, 2016 | 10:45 PM
  #68
Wolftrk99's Avatar
Need to look into that!!!
Old Jul 2, 2016 | 10:54 AM
  #69
07Softail's Avatar
Im debating on a stock camaro or caprice converter or something along the lines of the circle d 278mm in a lower stall, don't want a really high stall... Its going in my yukon behind the 6.2 im building, and its the family hauler/road trip vehicle. I am using a vvt cam in it as well, so in all probablity dont need the higher stall...
Do you have the Caprice, Camaro converter part numbers?
RT
Old Jul 2, 2016 | 11:40 AM
  #70
Wolftrk99's Avatar
I can get it tuesday, had found it through dacco but cant remember what it was now, but it was far less than the gm reman...150 vs 450
Converter code is jmbx
