Just ordered FLT trans. have a few Q's
Old Feb 3, 2006 | 09:36 PM
Default Just ordered FLT trans. have a few Q's
I just ordered a 4L65E from FLT today and had a couple of questions. Should I replace the flexpalte? My truck has 150,000++ on it. If so were to buy? Also the a stall convertor from a 4L60E is the same right?
Thanks
Danny
Old Feb 3, 2006 | 09:42 PM
TravisH's Avatar
Your flexplate should be fine, and the TC will work too.
Old Feb 3, 2006 | 09:45 PM
What is a is a good stall for the trucks?(RPM wise) I was looking at the Yank convertors. I am also going to be puttin' a cam in the truck too. Not sure of the specs just yet but I'm thinking 2800-3000rpm is bout right. What do ya'll think?
Old Feb 4, 2006 | 01:19 AM
TravisH's Avatar
What size cam do you want?
I would reccomend a TB stall or a Dacco 2300-2500 w
...I gained .4 in the 1/8 th with my 2800-3200 and .2 in my 60'
Old Feb 4, 2006 | 01:31 AM
The cam depends on what I can pass smog with. I need to do a little more research on that though. If I remember right I think I can't go past 220 at 0.50. Not sure yet. And the cam is going to be for the 6.0 too.
Old Feb 4, 2006 | 01:53 AM
AintNoHo's Avatar
Flexplate doesn't need to be replaced. Converter only needs to be replaced if the old tranny grenaded and has metal in the fluid. I passed smog with a 2500 stall (flashed to 3000) and a 208/214 cam. I'm sure I could have used more duration and a ls1 probably could use more still.
Old Feb 4, 2006 | 07:57 AM
FLT's Avatar
FLT
FormerVendor
Default Do NOT...
If your installing a new trans, it would be best to at least have your tc cut and cleaned. Also flushing the cooler is a good idea!! Chuck is one of the best out there and you will be very happy with his product. GOOD CHOICE
Old Feb 4, 2006 | 10:24 AM
I am not going to use the old convertor. My tranny was not in very good shape with 150,000++ on it. I am losing 1-2 and overdrive so I know it has to have some metal in it.
I didn't think of the cooler. Man I'm glad you said that. I need to upgrade that too. And clean the lines out.
I'm going to pull the motor and trans and replace with the 6.0 and 4L65E. Damn I need a cam. Heads too.
Thanks Guys
Blwn99x
Mar 24, 2023 11:14 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
trxmxzx
Sep 29, 2015 07:42 AM
