jakes stage 3 showed up
Old Mar 9, 2014 | 09:04 AM
  #51
billy smart's Avatar
I bought this part# line from dealer 15832205. It worked perfect to the rear cooler fitting on my year trans to the front aux. cooler. It was $33. I bought a yoke from ebay for $67 and cut aprox. 1 inch off. This is the yoke GM Turbo 400 TH 400 4L80E Transmission Transfer Case Slip Yoke s 44 Joint | eBay.
Old Mar 9, 2014 | 09:12 AM
  #52
Choda's Avatar
I Also dd a Tru cool 40k
  #53
03sierraslt's Avatar
Originally Posted by bud8fan
what...mine is built into the bottom of my boost cooler...it's 35* during the burnout
But you are not DD it at those temps either. By the time you launch of the brake I bet there is plenty of heat there. We are talking about something that gets driven continuously at those temps.
Old Mar 9, 2014 | 10:59 AM
  #54
greasemykey's Avatar
that part comes back as a dip stick tube from ac delco
Old Mar 9, 2014 | 11:53 AM
  #55
oh so do i need the other vss sensor plugged in for the trans swap? i thought i read that i dont need it and that i can run the 80e like the 60e? bought the yoke this morning but i forgot about the other vss. about to buy all the fittings and the cooler i just need to know about the forward VSS on that trans.
Old Mar 10, 2014 | 07:55 PM
  #56
Thank you Chris at circle d. trans will be going in this weekend. may not be able to drive it but i will have it in.
Old Mar 10, 2014 | 07:57 PM
  #57
Looking good man.
Old Mar 10, 2014 | 08:56 PM
  #58
Sierra how did you set up your wiring on your 80e?
Old Mar 11, 2014 | 04:19 AM
  #59
Segment swap PCM, added in ISS via factory wiring. ( re pin trans plug, and move some wires around at PCM plugs). I am on my phone or I could link you to exactly what I did. I added my way to the drivetrain stickies.
Old Mar 11, 2014 | 08:07 AM
  #60
Circle-D's Avatar
Former Vendor
Looking forward to your updates.....
Sorry for all the UPS troubles.
Chris
