jakes stage 3 showed up
#92
The stock rear u-joint from my 1500 2wd 2006 crew cab with the one piece aluminum ds worked for the front joint when i swapped to an 80e. I used a 400 yoke from ebay also. If I remember correct you need it to have outside and inside clips. I had to cut a little off my yoke, other than that it was a straight forward swap. I'm 90% positive it was a Precision #355 from O'riellys
#93
ebay slip yokes suck *****. took her to a drive shaft shop to be shortened and I needed on ear to be heated and shrunk down because the u joint could slide through and the ears needed to be widened because the clips couldn't get in the groves of the u joint. should have bought a spicer joint. lesson learned but the shop was awesome and was able to fix everything for me so tomorrow ill have the drive shaft in and the cooler lines made and installed. hopefully I can figure out why my HP tuners wont read. I think my battery in my truck is low from sitting.
#97
driveshaft and trans lines are installed. going to try and get my tune off my PCM tomorrow so i can get the segment swap done. at this point the only thing im waiting on is the shift cable bracket and dipstick tube. the Lokar one i bought is stupid short so i guess i need to sell that on ls1tech. should be up and running by saturday. gmpartsdirect shipping is retarded slow. 2 weeks from the date of order before i will receive my parts.
#99
they got it hooked up and fixed. wasnt that bad i just didnt really think about it not working since other member here have used the same joint and not had issues. they heated and shrank the oversized ear and stretched them apart so i could install the clips. all said and done was 20 bucks. still debating having a custom drive line built at some point. not sure who to call or what i should order. any ideas?
wickedRCSB
Oct 10, 2015 09:29 PM
carid
Oct 1, 2015 09:22 AM
