jakes stage 3 showed up
#72
You dont need to run the dustcover. You'll actually get better cooling off the converter with it off. It's not there for structural support. If my truck wasn't so low to the ground I wouldn't run it. In fact, before I was dropped I didn't run the dustcover.
#76
so i put together all the parts that i have and realized the 80E does not have the ISS sensor installed but a block off plate instead. can i use my 60E VSS or do i even need the ISS? i thought there was a way to run the 80 like the 60.
#77
So jakes 80e's don't come with cooler fittings and both vss/iss sensors?
