Installed SUV rear brakes on my Silverado
#21
This is really cool! I have a question thou.
Is it possible to swap front brakes from a 05+ truck to a 99-04 truck? The reason i ask is the fronts on 05+ are bigger (1 inch i think) than the 99-04. So if you did the rear suv brakes and 05+ fronts that would be a pretty decent brake upgrade. any thoughts?
#22
It is a marked difference in stopping ability and for much less than aftermarket. You absolutely must have 17" or bigger wheels to run them though.
#23
Awesome, thanks for the response, that is exactly what i needed to know!
#25
so 05+ fronts.
Are the 04 trucks rears the same as 99-03? I assume since they went to drums in 05, so i can still do the tahoe upgrade right?
What size difference is there in the regular rotors and the 05+ and tahoe rotors?
#26
Here are the specs on the brakes rotors.
Single piston-18 mm thick
Double piston- 28 mm thick
The diameter is the same only the thickness varies. I made the mistake of purchasing the wrong rotors. I knew about this mod, just didn't want to spend the money on new calipers and brackets.
#28
theres also a 30mm rotor, which is the one i used. the Z71s and Escalades use that one. the rotors i used came off a Z71 suburban, JH6 brake option.
and no sharpshooter, they won't work. you need to use the correct rotors and brackets
