Installed SUV rear brakes on my Silverado
Old Jun 17, 2013 | 01:34 PM
  #111
pdxmatt's Avatar
Yes you can. It's just not a direct swap. As noted, the mounting flanges are clocked differently (not a big deal) and you will need rear e-brake cables and you will need to get or make hardlines for the the rear axle, along with the two flex lines to go to the calipers.
I made my own hard lines and bought a Russel stainless braided line kit for a disc truck and used that.
Pretty happy with it.
Old Jul 18, 2013 | 06:31 PM
  #112
bull0109's Avatar
I know this was asked once but never saw an answer what is the part number for the calipers you guys are using
Old Sep 4, 2013 | 09:06 AM
  #113
firebladeJJ's Avatar
I just did this upgrade on my rcsb 04 sierra. SUV rear dual calipers and 05+ front brakes with SS brake lines. GREAT UPGRADE!! I wasnt so impressed the upgrade right after we got done but 2 days later the brakes are fan-freakin-tastic!! I used the part number from the "Budget brake upgrade" thread.
Old Sep 4, 2013 | 03:58 PM
  #114
ShredSled's Avatar
Which SS lines did you use?
Old Sep 4, 2013 | 04:59 PM
  #115
I used the russell 672470 for my truck, you might go on russell's website and look for your application.
Old Sep 18, 2013 | 09:58 PM
  #116
geoffmt's Avatar
Default 2001 gmc, 9.5 in 14 bolt
Here is a different question for the brake upgrade. I exploded my last 10 bolt(I did that a lot), and my best friend replaced it with a 6 lug 14 bolt and rear calipers off a 85ish caddy with built in ebrake. as all 2001 gmc's the brakes still suck bad trying to stop my weld 16 in wheels with 35 in bfg mud tires. Is there a 2 piston rear caliper without the drum ebrake? any front brake upgrades for the front that will fit the 4x4 while still using the 16 in weld outback wheels? Brake pedal is very spongy and the rear calipers want a wider disc than my stock replacement Baer discs.
Old Sep 18, 2013 | 10:04 PM
  #117
truckmann's Avatar
I don't know about any other calipers that might work but if you want better stopping power I would suggest going to a hydroboost setup.
Old Sep 19, 2013 | 09:47 AM
  #118
truckmann's Avatar
https://www.performancetrucks.net/fo...nstall-417445/
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
mrgrim
Jul 8, 2015 08:12 AM
