Installed SUV rear brakes on my Silverado
Old Aug 9, 2010 | 09:05 AM
  #21
BlackGMC's Avatar
Resident Retard
This is really cool! I have a question thou.
Is it possible to swap front brakes from a 05+ truck to a 99-04 truck? The reason i ask is the fronts on 05+ are bigger (1 inch i think) than the 99-04. So if you did the rear suv brakes and 05+ fronts that would be a pretty decent brake upgrade. any thoughts?
Old Aug 9, 2010 | 09:28 AM
  #22
Coban's Avatar
Yes, I did the 05+ fronts as well. You need caliper + bracket and new rotors...
It is a marked difference in stopping ability and for much less than aftermarket. You absolutely must have 17" or bigger wheels to run them though.
Old Aug 9, 2010 | 09:29 AM
  #23
BlackGMC's Avatar
Resident Retard
Awesome, thanks for the response, that is exactly what i needed to know!
Old Aug 9, 2010 | 05:04 PM
  #24
qwank's Avatar
these rear brakes really clamp a lot better. i had a chimpmunk run out in front of me this morning and the rears locked up!
Old Aug 9, 2010 | 06:57 PM
  #25
slamdlsx's Avatar
so 05+ fronts.
Are the 04 trucks rears the same as 99-03? I assume since they went to drums in 05, so i can still do the tahoe upgrade right?
What size difference is there in the regular rotors and the 05+ and tahoe rotors?
Old Aug 9, 2010 | 07:27 PM
  #26
SilverDog's Avatar
Here are the specs on the brakes rotors.
Single piston-18 mm thick
Double piston- 28 mm thick
The diameter is the same only the thickness varies. I made the mistake of purchasing the wrong rotors. I knew about this mod, just didn't want to spend the money on new calipers and brackets.
Old Aug 9, 2010 | 07:38 PM
  #27
sharpshooter's Avatar
can the suv calipers be used with our truck rotors and our our mounting bracket?
Old Aug 9, 2010 | 08:25 PM
  #28
qwank's Avatar
theres also a 30mm rotor, which is the one i used. the Z71s and Escalades use that one. the rotors i used came off a Z71 suburban, JH6 brake option.
and no sharpshooter, they won't work. you need to use the correct rotors and brackets
Old Aug 9, 2010 | 08:38 PM
  #29
ap2002's Avatar
Good info, this should be a sticky!!
Old Aug 21, 2010 | 03:40 PM
  #30
brent5631's Avatar
Do the tahoe calipers have the banjo bolt in the same location?
I am having trouble fitting wider 16" rims and wanted to use these instead of s10 calipers.
