Installed DJM Uppers and Lowers
I installed DJM Upper and lower a-arms on my 4wd. Previous set up was McGaughy spindles and lowering keys for about 5" of drop. It rode horrible!!
Now I have DJM arms, McGaughy spindles, and lowering keys. Probably close to 6" of drop. The keys are almost all the way up and it is still a little too low. It rubs on going over bumps. I am going to try to crank it up a little more (if I can find my stock keys) and see where it is rubbing.
Those of you that are slammed up front, what do you do to the inner fenders?
One issue I dont have any more is the turning radius issues and binding issues. It should align fine as there is plenty of adjustment in the uppers.
Here are a couple of pics, the truck is dirty.
That looks awesome !
So you no longer have turning radius issues ? , hmm that's good, mine turns like a bus , takes the whole parking lot and lots of reverse action since I installed my McG"s spindles . I love em but damn my crewcab turns tighter !
I had 285/35's before and they rode bad, so I went with 285/40's this time around. Kind of wish I would have stuck with 285/35's now.
Many other guys have done it, Black04 was the first I think, and he is kind of the reason I did it.
Thanks!!
Nope, no more turning issues, my reg cab did before. It was horrible! It also used to bind up close to full lock and felt like I was turning on gravel. That is gone too.
Asanti 22x10's all they way around with Toto Proxes ST2 285/40's.
for the front inner wheel well you can cut out the area that tapers down to the fender lip and install a patch panel higher up and level. If that is not enough you can cut them out completely and make some new wheel wells out of trailor fenders or wheel tubs.
signguy62
Jul 27, 2015 03:42 PM
carid
Jul 24, 2015 05:00 AM
