I found it! Beware B&M Flexplates
Old Apr 19, 2013 | 10:24 PM
06sierra5.3's Avatar
Default I found it! Beware B&M Flexplates
So I posted last weekend about my broken Flexplate. I ordered a B&M SFI rated flexplate through Summit. Before replacement I had an intermittent pinging/tinging whatever. After installation of the new plate, the noise was louder, more metallic and consistent.
I started the truck 4-5 times, let it run for a few seconds then turned it off. Took the tranny out and could not find ANYTHING.
last night I put the tranny back in. I left the torque converter un bolted. I started it, same noise. I let it run for a bit. Definitely not in the tranny, definitely not flat or solid enough to be a rod knock. HAS to be the starter, so I started looking.
I don't know how the hell I spotted it with everything installed, but the flexplate is hitting the starter bearing in the front, where the gear comes out and stops.
the B&M flexplate is about 2-3mm too large in diameter.
Here it is lined up with the GM plate
you can see here it's barely starting to wear the starter bearing on the back half
Here i where I spotted it, in the black void (cant be seen in the pic)
Here is the bearing more worn now. The flexplate was hammering it, not scraping it
Here is a video of the sound
20130419_192321 - YouTube
Old Apr 20, 2013 | 12:37 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Starter shim would fix that pretty easy.
Old Apr 20, 2013 | 01:17 AM
I don't even know what a starter shim is, i'll look it up.
Old Apr 20, 2013 | 01:30 AM
k I found them. How would I shim this starter though, the bolts go straight up and a shim wouldnt let the bolt holes line up.
Is there a different starter I could buy?
Old Apr 20, 2013 | 01:48 AM
Kemble's Avatar
The shims will space the starter down from the block, giving more clearence for the flexplate.
Old Apr 20, 2013 | 12:30 PM
smokeshow's Avatar
Mod with training wheels
Same thing happened to me with an aftermarket flex plate. Put about .060" worth of shim in and the noise went away.
Old Apr 20, 2013 | 12:49 PM
Thanks guys. I'm going to put some washers in between the block and starter for now to see how much I need to make the sound go away.
Old Apr 20, 2013 | 06:16 PM
two stainless 1/16" washers and it's fixed. Thanks for everyone's help
Old Apr 20, 2013 | 11:28 PM
I'd rather have an actual starter shim in there than the washers. But glad you figured it out.
Old Apr 21, 2013 | 09:31 PM
Im ordering them, I just needed to get it going. 4 hours round trip today, not a hiccup.
