How much abuse will the 1/2 ton transfer case handle?
Old Oct 23, 2006 | 11:07 AM
Stampede4ever's Avatar
Default How much abuse will the 1/2 ton transfer case handle?
In 2wd.
Thanks.
Old Oct 23, 2006 | 11:32 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
? You plan on running with the drive shaft out?
Old Oct 23, 2006 | 01:21 PM
thunder550's Avatar
High on diesel fumes
There was a thread about this awhile back, but IIRC it was about 5500 ft-lb (keep in mind, in low range 1st gear multiplies engine torque by LOTS so that 5500 number isn't quite a high as it sounds). I am running the 1/2 ton t-case in my truck and Parish ran it with no problems into the 700 rwhp range. There are plenty of other things that will break before your t-case will break (tranny, driveshaft, rear end, etc).
Old Oct 23, 2006 | 01:27 PM
thunder550's Avatar
Here ya go. I guess I didn't remember correctly, cause mine is an NV246 which is 2281 ft-lb
http://www.newventuregear.com/tcases.html
Old Oct 24, 2006 | 11:02 AM
Thanks.
I'm thinking of a manual trans.
And it can be engaged (4x4) and disengaged (2x4)?
Thanks.
Old Oct 25, 2006 | 07:38 AM
Whippled 496's Avatar
I got the NV263HD, so I think i am good to go....
Old Oct 23, 2010 | 09:09 AM
TURBHOE's Avatar
damnit!!! we should have copy and pasted that chart. its not there anymore cause they sold out to another company i guess. i'm trying to remember what the 149 case was rated at. i thought it was 2200. Whippled, what was yours rated at?
Old Oct 23, 2010 | 01:00 PM
1Bear's Avatar
The chart is saved in the documents section of DenaliTrucks dot com if you need it.
Old Oct 23, 2010 | 06:29 PM
budhayes3's Avatar
PT's Slowest Truck
Nice! Jarrod to the rescue again!
Silver8ado
13
Oct 21, 2024 09:09 AM
bluestang50
Sep 21, 2015 08:36 AM
69z-28
Sep 21, 2015 07:31 AM
Silver8ado
Sep 14, 2015 06:35 PM
dselby25
Sep 11, 2015 05:03 AM
