G80 grenaded - what are chances trans is hurt?
Old Dec 20, 2011 | 12:41 PM
00ChevyScott's Avatar
Wearin' da big hat
Default G80 grenaded - what are chances trans is hurt?
Turns out Royces G80 blew up and it wasn't the tranny. Hes got a built tranny, what are the chances the output shaft on the tranny is tweaked?
Old Dec 20, 2011 | 01:17 PM
slow67's Avatar
Gingervitis Addict
What transmission, and was it during a launch?
Old Dec 20, 2011 | 02:05 PM
Wearin' da big hat
Its a 4l60e, no billet shafts. And he said he was going around a corner and it jerked hard
Old Dec 20, 2011 | 02:10 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It all depends on how and when the rear broke. Put it in neutral with the engine off disconnect the D-shaft from the rear end and turn the D shaft clock wise if i remember correctly. If your looking at the back of the trans output shaft. I believe in 1 direction it wont turn. You should have some good tough resistance but it should be smooth.
if its not smooth, if there is no resistance, or if turns and then stops or locks up in a spot its gonna have to be gone through.
Old Dec 20, 2011 | 04:06 PM
TXSZ66AVLANCHE's Avatar
Pull the d-shaft out and look at it!
Old Dec 20, 2011 | 05:56 PM
Vince B's Avatar
Its pretty common to damage a low roller race and or the input sprag when the rear lets loose. Might not be an issue right away but I have seen flat spots in the races from the shock of the rear breaking.
Old Dec 20, 2011 | 06:31 PM
smokeshow's Avatar
Mod with training wheels
G80 blowing up took out my old 60e...brake stalling did it.
Old Dec 20, 2011 | 07:18 PM
dirt track racer 81's Avatar
I stripped the teeth on the pinion once and got the input sprag..
Corvette454l88
Sep 1, 2016 01:24 AM
97aztecgt
Aug 13, 2015 02:11 PM
vmaxpro
Aug 8, 2015 10:49 PM
Aboss
Jul 9, 2015 10:28 AM
