found my transmission bleeding out.
Old Mar 16, 2009 | 12:54 PM
colekill's Avatar
KickinAssAndTakinNames
Default found my transmission bleeding out.
so, it has been raining down in texas for about a week now, and my truck has waiting in the garage for it to stop. i come home last night and notice a rather large puddle transmission fluid glaring back at me. i got under there and looked around nothing seemed out of place. so after some thinking i have come up with this: is it possible for all the transmissiond fluid (when sitting for about 6 days) to drain out of the lines and tranny itself back into the pan? i belive the bracket that holds the dip stick tube had been bent alittle, and the tube did not sit like i thought it should, but i thought it would be fine. so i think the fluid filled up the pan and then dumped about 2-3 quarts of fluid out from around the dip stick tube.
dose that sound right to yall?
was there an o ring between the tranny and tube?
Old Mar 16, 2009 | 01:06 PM
terravast4's Avatar
There is a seal on the dipstick tube and if the tube gets crooked it will not seal properly. i had an old turbo 350 that would leak a shitload of fluid from the exact problem.
Old Mar 16, 2009 | 01:10 PM
colekill's Avatar
is it going to take a new tube?
Old Mar 16, 2009 | 08:00 PM
StrokerAce03's Avatar
Check the rear seal where the slip yoke goes in as well. Mine is leaking from there currently.
Old Mar 17, 2009 | 06:07 AM
terravast4's Avatar
If that tube is crooked it may have pinched or broke that seal. I had that trans in a 68 nova and had clearence issues with the firewall so I was always swapping out tubes to find one that would fit.
Old Mar 17, 2009 | 06:55 AM
KySilverado's Avatar
Mine is leaking after it sits for several days. Coming out the main electrical connector.
ferrellrooster
Mar 6, 2025 03:22 PM
ARC
57
Feb 21, 2022 10:54 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
JFortner5
Aug 20, 2015 06:13 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
