Flip kit for 6 lug 14 bolt and swapping disc brakes questions
Old Dec 6, 2012 | 11:40 AM
nickleahy23's Avatar
Default Flip kit for 6 lug 14 bolt and swapping disc brakes questions
This is for my 99 rcsb 4x4. Im going to throw a 14 bolt 6 lug under my rcsb for peace of mind. Ive blown up enough 10 bolts and i would rather spend the money on a 14 bolt. Im going to be running a 6" flip kit so im wondering what kit im going to have to order for this axle. I know its going to drop it differently since the axle tubes are bigger on the 14 bolt.
Also, im going to want to swap my disc brakes onto the 14 bolt and I cant seem to find a thread on it. I know ive seen it before. Any info on that would be great. Thanks guys
Old Dec 6, 2012 | 03:03 PM
Guessing run a 92-2000 C2500 flip kit for a 7" drop and then a lift shackle for 6" total drop?
Old Dec 7, 2012 | 06:13 AM
Beatdown Z's Avatar
Laid Back
That sounds like it would work.
Old Dec 7, 2012 | 09:24 AM
Last Call's Avatar
TOTM: January 2007
Which 14 bolt are you going with? If it an 05 and up unit, the disk brakes will bolt up and you can use the same flip kit for a 10 bolt.
Old Dec 7, 2012 | 11:36 AM
its from a 92 c2500. Painted, new fluids, same gears and new brakes with a limited slip for $150 lol
Old Dec 7, 2012 | 10:39 PM
1FastBrick's Avatar
Custm2500's Rude Friend
How do you plan to attach the factory tahoe disc brakes to that rear end???
Most people make spacers or shims.
Is this the thread you were looking for??? It covers most all the specific info and has a link to other builds.
https://www.performancetrucks.net/fo...thread-467473/
Old Dec 9, 2012 | 03:51 AM
i bought a 99 rcsb a few weeks ago, and it has the stock discs..i will read through that thread, i think that was the one i read a while ago so that should help. Thanks for the link!
Old Dec 20, 2012 | 06:37 AM
james8997's Avatar
How? The axle tubes the same diameter?
Old Dec 20, 2012 | 11:12 AM
i know the axle tubes are bigger on the 14 bolt, so i would have to get one from a 88-98 2500 and use a lift shackle to get it at 6"...but might be slight change of plans for now, thinking of going up with it a little bit until i have everything in line for the 6.0 swap and such..I already have the lowered tahoe, so it would be nice to have something up in the air a bit for hunting and messing around
Old Dec 22, 2012 | 06:19 PM
james8997's Avatar
Unless the newer ones have smaller axle tubes, ill measure some tomorrow, I have both
