eaton posi?
Old May 26, 2011 | 06:59 PM
slowswb's Avatar
Default eaton posi?
im looking for the rebuild kit for my true trac where to find the kit to rebuild it.
Old May 26, 2011 | 07:49 PM
terravast4's Avatar
Tru-trac is not a rebuildable unit
Old May 26, 2011 | 08:35 PM
Beatdown Z's Avatar
Laid Back
What happened to it that requires rebuilding?
Old May 26, 2011 | 11:52 PM
Chevy-Fun's Avatar
Dang I was lookin into the try grab since most of Yall push it. But not rebuildable. Wut happened to urs.
Old May 27, 2011 | 12:56 AM
YodiBrodi's Avatar
trutrac isn't even an eaton diff. it's detroit, unless eaton owns them.
Old May 27, 2011 | 12:48 PM
slowswb's Avatar
The posi isnt grabing my slick are wearing uneven
Old May 27, 2011 | 01:36 PM
slowswb's Avatar
sorry meant detroit
Old May 27, 2011 | 01:38 PM
1Bear's Avatar
Correct, the TruTrac units are not re-buildable.
Eaton in fact does now own the Detroit brand.
Are you by chance using synthetic gear oil? This is a fairly common issue that arises and it is recommended by the manufacturer to use conventional gear oil instead with the TruTrac differentials.
Old May 28, 2011 | 08:43 PM
slowswb's Avatar
synthetic gear oil is what i am using thanks for the great tip.
Old May 29, 2011 | 06:10 AM
06Sierra2's Avatar
i have also heard the same thing several times. switch over and see if it helps. i wouldnt know for sure as i have only ran dino but hopefully it helps u
Go5.3tt06
25
Sep 4, 2016 10:25 AM
moregrip
Jul 26, 2016 11:21 AM
turbo6c3
Oct 5, 2015 06:11 PM
lsxperformance
Sep 14, 2015 10:53 AM
