Drop shackles
Old Dec 27, 2009 | 05:49 PM
PHQ2's Avatar
Default Drop shackles
Installed 2" drop shackles on my 92 GMC today, now it doesn't sit level, 5/8" out. Drove the truck thinking that they needed to seat in ( both were tightened up with weight on the truck ), no luck. Both were installed in the same hole on each side. Used Bell Tech shackles, so they ought to ne good, confused!
Old Dec 27, 2009 | 06:17 PM
RandomHero's Avatar
What doesn't sit level about it? If one side is higher than the other then that's just the infamous chevy lean. Get used to it I hate to tell you. There are ways to accommodate the height difference though.
Old Dec 27, 2009 | 06:20 PM
dlt76028's Avatar
yea, what are you referring to?
Old Dec 27, 2009 | 07:41 PM
PHQ2's Avatar
Sorry, drivers side is lower than the passenger side
Old Dec 27, 2009 | 07:46 PM
dlt76028's Avatar
thats very common. you should adjust your drop shackles on the drivers side up one hole, or you can get a half inch block on the passenger side to lower it.
Old Dec 28, 2009 | 03:46 PM
BlackLM7's Avatar
Your truck was probably always lower on the driver's side but now it's more apparent since the truck is lower. The issue you describe is more commonly known as "Chevy Lean". It's a "problem" that many full size GM trucks have, although less common on the '88-'98 trucks. The lean doesn't affect how your truck rides or handles.....it's all visual.
Old Dec 28, 2009 | 07:18 PM
PHQ2's Avatar
I was thinking of doing that but did not know if it was kosher
Old Dec 28, 2009 | 07:20 PM
PHQ2's Avatar
Really never noticed it before, your probably right. Just sucks!
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Chewy07
Nov 14, 2015 09:46 PM
Gadgetized
Oct 22, 2015 09:06 AM
vmaxpro
Sep 28, 2015 11:10 AM
twake_410
Sep 25, 2015 10:09 PM
