my LVL5 is taking a trip to IL
Old Dec 27, 2009 | 09:05 PM
sharpshooter's Avatar
Default my LVL5 is taking a trip to IL
I've had my LVL5 for almost 2 years behind my set-up below and it has been awesome.I've never had a problem with it and everytime I drive my truck I run the **** out of it.I think my truck stresses it pretty hard.It is not my DD.
I've had a flare at the 2-3 shift at wot for a couple of months.About a week ago I was driving and lost 3rd and 4th gear,so I limped it home.I knew I probably wore out the 3-4 clutch pack.I called FLT and talked to Andy and that would be his guess also but he also said he won't know until they get it open.Sureshot and I took it out of the truck yesterday.I pulled the pan after it was out and was real happy to see only clutch material in the bottom.
Andy said they will get it fixed up and do some up dates they do since mine was built.Thanks for the great customer service and I'm already ready to get it back on the road.
I know this is a wear part so I have a few ideas to help it out.Recently Justin added a small amount of torque management at that shift.I also think running the big cooler I do actually keeps it to cold in winter.When it is cold it doesn't have the line pressure it has when it is warmed up.So I'm going do something to actually keep some heat in it for the winter.
Old Dec 27, 2009 | 09:11 PM
viciousknid's Avatar
Where's the Beef?
Same here. Just waiting until after the Holidays to get the shipping sorted out. Same problem but my fault for not finding out why I was blowing fluid.
Old Dec 27, 2009 | 09:36 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
That's why I'm planning a 25k or 30k cooler this spring, rather than the 40k. Too cold here for a 40k.
Old Dec 28, 2009 | 08:24 PM
Beatdown Z's Avatar
Laid Back
My trans runs real cold too, even with half of my 40k covered up with a piece of metal, lol. I might switch back to my stock t-stat and maybe try out that thermal bypass thing.
Old Dec 28, 2009 | 09:14 PM
That's funny man,I was thinking of blocking a portion of mine with a plate also.I'm wondering if I should try my stock cooler again.My tranny seems a lot better when it is above 150*.
Old Dec 28, 2009 | 09:19 PM
ChevyTruck's Avatar
something else
Man that sucks that happen to you. I will be dropping my trans soon too, want to help? Joking.
Hope its not too bad of a fix for you.
Old Dec 28, 2009 | 09:20 PM
Beatdown Z's Avatar
Laid Back
Give it a try, can't hurt anything. I have to drive around in 3rd gear, beating on it with my fans off for my trans to see 150*, lol. These built trans' seem to run a lot cooler than "slippery" factory ones.
Old Dec 28, 2009 | 09:22 PM
sureshot's Avatar
Did you figure out what is going on with yours?
Old Dec 28, 2009 | 09:28 PM
Mangled03gmc's Avatar
Baltimore Whore
Y'all dang hill billys needs to learn not to run ya'lls truck so hard afters a night of swigging on thare moon shine
All in all, hope you get it squared away Russ
Old Dec 28, 2009 | 09:31 PM
ChevyTruck's Avatar
something else
I posted in my thread, I don't want to hi-jack sharpshooter thread.
lucas287
31
Jan 12, 2021 06:18 AM
Glenn98ZM6
Sep 18, 2015 07:31 PM
11MPG
Sep 10, 2015 08:34 PM
pewter00
Sep 7, 2015 10:14 PM
