Drive shaft
Old Apr 19, 2009 | 02:29 PM
black04silverado's Avatar
Default Drive shaft
long story short
u joint came apart drive shaft hit the ground broke
i need a new one but dont know where to get one
and right now i have a 2 peice and i have heard a one peice is better?
Old Apr 19, 2009 | 03:20 PM
dlt76028's Avatar
i got mine at the salvage yard. and i think yours is too long for a one piece. i dont think i've ever heard of the two piece failing
Old Apr 19, 2009 | 04:50 PM
well it was the rear u joint it came apart some how im not sure how but it did so i have to fix it and i will call some tomorrow what price range am i looking at?
Old Apr 19, 2009 | 04:55 PM
00Silv4.8's Avatar
a local shop here charges about 300 for a custom built one piece. I donno about 2 piece so it could be worth it to call around? other than that a junk yard is the best bet
Old Apr 19, 2009 | 04:59 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
2 piece is better, can handle more HP with less vibration.
Old Apr 19, 2009 | 05:16 PM
ok thanks guys i will call a few junk yards around here
will it be ok just to replace the back drive shaft it says on it to replace together?
Old Apr 19, 2009 | 06:21 PM
viciousknid's Avatar
Where's the Beef?
You'll want to ask your local dealer. Probably have to buy it all together knowing GM.
But whoever said 1 piece is better didn't know your truck is extended cab. 2 short shafts vibrate less than 1 long piece. Less vibration means less likely hood of breaking.
Old Apr 19, 2009 | 06:24 PM
JakeBrakeIH's Avatar
I picked up a used 2 piece from a local junk yard for 50 bucks for my T56 swap...and it was about the 2nd junk yard I called too
Old Apr 19, 2009 | 06:30 PM
sweet so i hope its not to hard to find i did find a place who builds them but im cheap and dont want to drop 400 bucks for one so i hope i can find a used one
Old Apr 19, 2009 | 08:48 PM
fredkj3's Avatar
is it the U-joint at diff??? if it is you probably have a pinion angle problem... my truck is lowered and when i would launch the pinion angle would go up and eventually destroyed my u joint and ruined my back shaft...
i got a new back shaft custom made with all new spicer U-joints for 300 bucks... if you find a back shaft at a junk yard get the front shaft too... they are balanced together so you shouldnt mix match them....
i would probably look into some caltracs if its a pinion angle issue.....
