Ditched the Torsion Bars for Coilovers on the HD
Old Jul 12, 2012 | 11:14 PM
  #21
midevil1's Avatar
Originally Posted by LsxCody
That looks pretty sweet.
Thanks...The ride quality is unreal. Like a 2012 F150....
Old Jul 12, 2012 | 11:17 PM
  #22
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by TIM Z
Yeah I'm thinking so also Joe, first I'm just wondering if the cv's clear for us 4x4 guys.
Tim, check out this thread. It may answer some of your questions about size & durability. Coil-overs done!! - Duramax Diesels Forum
Old Jul 12, 2012 | 11:21 PM
  #23
Atomic's Avatar
I have a gauge for that
Thats awesome!
Old Jul 13, 2012 | 06:29 AM
  #24
midevil1's Avatar
That is why I made solid bushings or just use the bearing type from QA1. The D-Max really needs the 1000lb springs.
I hit a stretch of road last night, that I hated to drive in the Denali. Didn't get a hard bump or rattle in my truck. The wife even said that this was my BEST mod yet...
Old Jul 13, 2012 | 07:36 PM
  #25
TIM Z's Avatar
11 sec. Truck Mod
Thanks Roger! You planning on doing this to your Dmax?
Awesome man!!!
Old Jul 13, 2012 | 09:32 PM
  #26
moregrip's Avatar
what a rush!
I like it.....alot. How long have you been running it like that? Be interested to see how the upper shock mounts hold up! I know ridetech does a similar thing but runs 1500 series t-bars. I'm in for updates!
Old Jul 13, 2012 | 11:15 PM
  #27
midevil1's Avatar
I have only been running them for a week. I installed a wide washer on top and bottom of the upper mount area to disperse the load better. I am not against welding a plate on top for more thickness but I don't believe it is needed..
Old Jul 14, 2012 | 07:59 AM
  #28
moregrip's Avatar
what a rush!
I've had the same idea as you but was thinking if I ever had the stones to do it I'd somehow design a heavy steel top plate that overhangs either side of the perch, have the ears bent down so that in addition to re-enforcing the top of the shock mount, they run along the side of it (maybe perfectly or at a 45deg angle). then you could either weld that to some flat stock that lays flat against the frame or bolt it to some L stock in a similar fashion. thoughts?
Old Jul 14, 2012 | 09:58 AM
  #29
midevil1's Avatar
In my research, I believe the shock itself to be the weak point. I talked with QA1 and they said that their housing's and ends will handle the weight. The shock I used is designed for high tension springs. I thought of all types of elaborate designs. I even tried to see if the F150 coilover setup from Rancho would work. ( it won't fit) I decided that the easiest route would be the first route.
Old Jul 16, 2012 | 09:50 PM
  #30
midevil1's Avatar
Drove down Gelhorn Drive today at 35mph. (Road in front of S and S.) All you guys familiar with Houston know this road for it's excellent rock crawling terrain. Truck drove perfect and NO failures. With the torsion bars I would have changed lanes 3 times at this speed.....
