check out my horrible driveline angles and tell me how to fix it
OH AND BOW TO MY PAINT SKILLZ
anyways with my truck sitting level the first half of my driveshaft slopes downward towards the rear end 2.5*. the 2nd half of the driveshaft is completely level. my rear end is point up towards the bed 7 degreez
shims arent going to fix this
any ideas on where to go from here?
im not sure what angle my transmission was sitting at so im not sure how much i can raise the DS carrier. im sure it wont be much until it slopes upward away from the tranny.
ok i was thinking wrong. i thought my pinion angle should point towards the ground only. from what i understand it can point towards the bed as long as its not point up higher than the driveshaft.
looks like 4* shims will put everything just about right????
By shimming the rear axle only you should solve 90% of your problems. A buddy of mine raised his carrier and shimmed the axle, he was running a 5/7 drop on ECSB. You are trying to achieve the same u-joint angle on each end of the shaft.
Try a search for driveshaft angle on the web.
yeah thats what im thinking.ill know more about it after i measure the tranny output shaft tonight. im not sure how far up i will be able to adjust the driveshaft carrier.
from what i understand is i need atleast 1* angle between each pinion and the slip yoke with 1-3* on the pinion below the rear portion of the driveshaft.
been runnin it this way for 3-4 years now
