C-notch- frame sag???
Old Aug 9, 2005 | 07:02 PM
Default C-notch- frame sag???
I put a McGaughy c-notch on my truck. I did what the instructions said. Now the rear bolts on the bed have a gap. I don't get it.
Otherwise the truck looks good. I don't know if it has settled completely. I have a 4/6 drop on the drivers side and a 3/5 on the passengers side. It is suppose to be a 4/6. ??? I still need to put fuel in the tank. The tank is empty. I hope it does not drop any more.
Old Aug 9, 2005 | 10:27 PM
No one with any experience?
Old Aug 9, 2005 | 10:37 PM
02BlueStepside's Avatar
When I notched mine, I left the bed on and only did one side at a time. I don't know if that made a difference or not, but I have no frame sag.
The drivers side is going to be slightly lower then the passenger side because a good bit of the weight is on the drivers side, a big one being the fuel tank. I never run more than half a tank in mine because of the lean. I know some have put a shackle on the passenger side to drop it an inch more to level it out, so that is an option.
Old Aug 10, 2005 | 10:37 AM
My friend and I did one side at a time, and put a jack under it. It sags about 1/2 inch on the back 2 bolts of the bed.
Old Aug 10, 2005 | 11:09 AM
12sec.5.3's Avatar
How hard was it to install the c-notch with the bed in place?
Old Aug 10, 2005 | 12:19 PM
Fairly easy for me, and it was the first time doing something like that. This was on a stepside if it makes a difference.
Old Aug 10, 2005 | 04:30 PM
12sec.5.3's Avatar
What did you use to cut the frame?
Old Aug 10, 2005 | 06:41 PM
leochevy2001's Avatar
i hope this doesn't happen with all mcgaughy's c-notches because i was thinking about getting one soon.
Old Aug 10, 2005 | 07:07 PM
LOW2000's Avatar
When I bagged my truck, I had the bed off and did one side at a time with a 2x4 shoved under the end of the frame to keep it from sagging before I got the notch on it. AFAIK, my frame is completely straight, but the AirRide Technologies notch is pretty beefy.
To cut my frame, I used a drill to make the top corners of the notch, then cut between the lines with a cut-off wheel and a sawzall. After I had the cut done, I went back over it with a 4" angle grinder to smooth everthing out.
Old Aug 10, 2005 | 09:40 PM
Cut off wheel. A sawzall works well too.
