Budget brake upgrade for 2000 Silverado. (05+ front, SUV rear)
Old Mar 4, 2015 | 02:27 PM
  #81
geoffmt's Avatar
Originally Posted by 99silversled
I have a set of Denali rear calipers and brackets 2 piston I was gonna use but just swaped in a fab 9 so not using if u still looking let me know
Any chance you still have the calipers and brackets?
Old Mar 5, 2015 | 03:51 AM
  #82
1bad2k's Avatar
If anyone has the backing plates, park brake cables and park brake parts, I will trade for my 06 front calipers and rotors.
Old Jun 25, 2015 | 08:11 AM
  #83
lucas287's Avatar
Originally Posted by iregret
I haven't installed anything yet. I'm still parts collecting. What trucks came with rack and pinion? Why would it make any difference? So long as the hydroboost unit is supplied with hydraulic fluid by the power steering pump it should be fine.
EDIT:
From what I've read, if you use hydroboost supply lines from a 2005 express van you'll be golden. Hope this helps.
Dredging this thread up, can anyone validate this about the van lines? I am gathering parts at the moment and don't want to experience any issues.
Old Jun 25, 2015 | 10:13 AM
  #84
iregret's Avatar
Charlie Murphy!
I can't personally confirm that it will work, but I can make an educated guess. I assume that it is correct because the Express Van is probably one of the vehicles that came with hydroboost that was 2wd. Any vehicle that had hydroboost plus rack and pinion should work. I know, Captain obvious. LOL.
Old Jun 25, 2015 | 10:54 AM
  #85
lucas287's Avatar
Thanks for the reply. That is my thought process as well. It would have to be the 1500 Express though, as im sure the 2500 does not have a rack and pinion. The only other thing I can think of that would be an issue is the hose/line length...
Old Jun 25, 2015 | 10:03 PM
  #86
1FastBrick's Avatar
Custm2500's Rude Friend
With a rack and pinion you just have to reshape the line.
https://www.performancetrucks.net/fo...w-pics-441147/
Old Sep 25, 2015 | 10:24 PM
  #87
01SilveradoJakee's Avatar
IM ALSO looking into doing an 2005 2wd Silverado 14 upgrade to me 2001 2wd Silverado and maybe Cadillac or denali rear brakes on my rear. Now do I have to run the hydro boost with this or can I not do that and have abs still work? Help??1
Old Sep 26, 2015 | 05:04 PM
  #88
bottledbird68's Avatar
You don't have to do the hydroboost conversion but that's where a lot of the upgrade in brake performance comes from. Adds a lot of clamping force over the standard vacuum assist
Old Sep 26, 2015 | 05:05 PM
  #89
And no matter which way you do it you can still keep the abs
Old Sep 26, 2015 | 06:12 PM
  #90
Only reason I ask because it seems like it's a pain in the *** to do the swap and I'm not 100 % sure
