Broke level 3 Performabuilt 60E
Old Dec 3, 2008 | 12:20 AM
  #41
kbracing96's Avatar
Originally Posted by built408
Theres no "might". You won't break a solid billet shaft, promise you that.
Next time it will just break something else, Believe me, If I though that billet shaft would make my tranny bullet proof, I would have put one in it. But I HATE swapping trannies on the damn floor, especially in a 4x4 and I have no lift. Got an 80e that I'm going though now that's gona go in there and I pry to god that will be the last tranny swap I will have to do on this truck,
Old Dec 3, 2008 | 07:36 AM
  #42
built408's Avatar
I hear ya, hopefully this one will last.
Old Dec 3, 2008 | 08:09 AM
  #43
FLT's Avatar
FLT
FormerVendor
Originally Posted by 2ktransam
I heard back from Performabuilt today about my trans. They said that I didn't actually break anything with power but I just had some bad luck. I don't know if I have this right but they said the seal on the front input drum came apart and started leaking fluid away from the front clutch packs. The clutches actually welded them self together from the friction.
Did Frank say it was an over run clutch seal on the piston or a Teflon seal on the input shaft?
Old Dec 3, 2008 | 08:45 AM
  #44
krambo's Avatar
Originally Posted by Vince @ FLT
And soon to be even stronger! We have a few new things in the works for you guys that may not want to do the 80 swap depending on your hp. We are hoping to be able to release the new trans after the first of the year. I believe it will be the strongest 4l6x on the market.
Your holding out on us! Kidding. Can't wait to see what you have in store , want a test mule?
Originally Posted by Wyttrash96
...Benchpressing a broken, expensive mess while it leaks an ocean of ATF on your garage floor doesn't make it any more fun either.
I laughed out loud when I read this. That totally paints a picture I have experienced.
Originally Posted by GMCtrk
Also take into consideration your truck weighs probably 500-1000lbs less than most people with extended or crew cabs. Apparently it's the extra weight that really kills these trannies.
Agree. However I have abused a 65E into the 11's many times weighing in at 5500#s. There was alot of stress on that puppy on every launch (AWD with Drag Radials) and I also had my share of street fun weighing alot more. The luck I have had with the 65E encouraged me to give it another shot with an additional 300RWHP.
Old Dec 3, 2008 | 09:58 AM
  #45
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Just clearing up .
Nothing broke the forward clutch molded pistion seal tore even with where the metal meets it around one side of the piston, this caused a leak and subsequently welded the forward clutch set together from slipping, The remainder of the trans is perfect,
I have not see this before and can only assume a faulty piston.
The seal was not rolled over just sliced even with where the steel piston meets it
Frank at PerformaBuilt
Old Dec 3, 2008 | 10:07 AM
  #46
built408's Avatar
I've seen it a few times, but it usually just causes a delay into drive and doesn't even burn the forward clutches.
Old Dec 3, 2008 | 10:24 AM
  #47
This one tore over a pretty large area i imagine it started out small and then over time grew
Old Dec 3, 2008 | 11:03 AM
  #48
built408's Avatar
I guess you got a defective piston, the ones I have seen are just small tears about 1/2 inch long.
Old Dec 3, 2008 | 11:13 AM
  #49
zippy's Avatar
I agree, those are strange simptoms for that failure. It's good though that it wasn't anything expensive or major. I'm a 60/65/70E supportor myself. Lately they have been holding their own on the fastest times board. They aren't too fond of turbo's with hard boost launches.
Old Dec 3, 2008 | 01:17 PM
  #50
Fireman31's Avatar
Glad to hear the problem was found and taken care of. I have been nothing but impressed with Frank's customer service and my Level 3 trans.
