Broke level 3 Performabuilt 60E
Old Dec 2, 2008 | 11:43 PM
  #31
GMCtrk's Avatar
Originally Posted by built408
You must not get out much, Myn held for 2 years with about 650-700rwhp with a stock output shaft. There is a member on this board with a built 60e and a trans brake behind a 427 on nitrous.
Well, I think it's safe to say you're in the minority there. Also take into consideration your truck weighs probably 500-1000lbs less than most people with extended or crew cabs. Apparently it's the extra weight that really kills these trannies.
Old Dec 2, 2008 | 11:48 PM
  #32
kbracing96's Avatar
Well the stock cryoed, TBSS 4l70e 4x4 output shaft I had put in my tranny wouldn't hold a 5.7 with 8psi of 4x4 brake boosted launches...
Not only are the splines twisted, but it's cracked though one of the oil holes and it about 2 1/2 shorter then it should be right now
Pretty much the same 5400lbs 4x4 truck as the OP
Old Dec 2, 2008 | 11:57 PM
  #33
built408's Avatar
4wd output shafts are weaker then 2wds. The 2wd's are longer and have room to twist without breaking. A billet one would fix that problem.
Old Dec 2, 2008 | 11:59 PM
  #34
built408's Avatar
Very true
Old Dec 3, 2008 | 12:01 AM
  #35
GMCtrk's Avatar
Who built your trans BTW?
Old Dec 3, 2008 | 12:02 AM
  #36
built408's Avatar
I did
Old Dec 3, 2008 | 12:06 AM
  #37
built408's Avatar
And from my experience, I have never had any luck with cyro'ing output or input shafts. Tends to make it more brittle and easier to crack. And every output shaft I have seen that has broke, breaks at that lube hole.
Old Dec 3, 2008 | 12:07 AM
  #38
kbracing96's Avatar
Ya it "might", but anther $550 into a tranny I aready have $2400 in, doesn't make since for a "it MIGHT hold" for a while. I rather sell this tranny to someone who isn't making near as much power and put something quite a bit stronger in it. (4l80e)
Old Dec 3, 2008 | 12:10 AM
  #39
kbracing96's Avatar
I was told the the factory does the cryoing on them in the new 4l70's...
It's only cracked at the lube hole, it twisted off right behind the drive spins,
  #40
built408's Avatar
Theres no "might". You won't break a solid billet shaft, promise you that.
