anyone ever run an in-line tranny filter?
was looking through a tranny parts book the other day...saw one...crossed the number to a Wix...we had it in the warehouse...
this isn't the remote mount, spin-on type...just an in-line magnetic filter for trannies and power steering lines...
http://www.wixfilters.com/filterlook...asp?Part=58964
anyone ever use one?
is it overkill?
is it overkill?
had that gayass thing on my one stang. didnt choose it ot be there was there when the previous monkey built the trans......all it did was cause me a leak
keep your trans lines as solid piece as you can get...magnets are in the trans to begin with
hmmm...guy at performabuilt seems to think they're good as long as they have a bypass feature...
https://ls1tech.com/forums/showthrea...57#post7842457
leaks is what I was thinking originally as well...
I tend to agree with Vince's take on them...
Little added advise. Many builders that do not do a good job in cleaning their valve bodies and parts, like these to help reduce future valve body issues. Most guy's that install these have issues and that is why they like them. If you were to install one, I would only do it after a trans failure and as mentioned above do not cut up your cooler lines to install one. If you are running an exturnal cooler that would be a good place to mount it for a short period of time and then remove it. This will help prevent any metal or debris that might not have been flushed out of a cooler after a trans failure. Vince
slowlsx
Aug 13, 2015 08:28 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
